Fuel tank
Posted: Sun Sep 19, 2021 3:00 pm
by nickacb
So my project to reproduce the rusted tank of my mk1 mini was a total failure. I decided to repair the original one instead.
I would like to ask for the purpose of one piece. In the bottom left of the tank it has kind of a short pipe that fits in a whole of the boot floor. Mine was blocked and just sitting there without being connected to anything
Could anyone pelase tell me the purpose of such piece please ?
I
Re: Fuel tank
Posted: Sun Sep 19, 2021 3:14 pm
by Fanfaniracing
Do you mean the draining plug?
Any pictures?
Re: Fuel tank
Posted: Sun Sep 19, 2021 3:42 pm
by nickacb
Right know Dont have pics but it is in the oposite side of the pipe wich connects to the main fuel líne.
Re: Fuel tank
Posted: Sun Sep 19, 2021 4:39 pm
by LarryLebel
Its a drain. It makes the tank hard to remove.
Re: Fuel tank
Posted: Sun Sep 19, 2021 5:15 pm
by nickacb
Ok, so the only purpose is to keep the tank in its place?
Re: Fuel tank
Posted: Sun Sep 19, 2021 5:39 pm
by Peter Laidler
No. It is a means of draining the tank down. Not fitted in the later years presumably because it made removing the tank and fitting it a bit of a PITFA. If you are going to repair the tank, maybe you could block this drain feature up.
If you post some pictures of the damaged/corroded area, some of us who have experienced corroded or damaged tanks will be able to comment on how they have repaired something similar, for you to copy. Pooled knowledge
Re: Fuel tank
Posted: Sun Sep 19, 2021 7:26 pm
by nickacb
Ok, I got it then, so I guess if you wanted to drain the tank without having to take it off the car altogether you could access this plug from bentih the boot or something like that
Thanx a lot
Re: Fuel tank
Posted: Sun Sep 19, 2021 8:23 pm
by Andrew1967
I fitted the drain tube back on to my car.
