Cooper S pin drive pump shaft replacement
65MK1S
Post by 65MK1S »
Has anybody pressed out the shaft on a Cooper S pin
drive pump and pressed it into one of the newer oil
pump impellers? I'm getting ready to try this. Wish
me luck :)
LarryLebel
Re: Cooper S pin drive pump shaft replacement
Post by LarryLebel »
I've done it ... no problem.
Easy … done it several times now.
And a cheap way of getting an AEG 410 pump without paying AEG410 prices, if you use an identical but short drive pin small bore Concentric oil pump.
65MK1S
Post by 65MK1S »
LarryLebel wrote: Fri Sep 03, 2021 3:40 pm I've done it ... no problem.
THANK YOU !!!!!
65MK1S
Post by 65MK1S »
Andrew1967 wrote: Fri Sep 03, 2021 6:07 pm Easy … done it several times now.
GREAT NEWS :)
Hugo
Post by Hugo »
I have a 1275 s and no one on earth seems to have an aeg410 so I think I'll do like you, I'm an experienced mechanic and machinist, tell me which pump you ordered and I'll replace the shaft
Has thanked: 116 times
Been thanked: 101 times
Mmmmmm, I wonder if 1071Bob has any views on this. Andy seems happy. I only ask because when something sounds too good to be true, it usually is.
Any views Bob and others
swifty
Been thanked: 26 times
Post by swifty »
Hugo , Chris AKA Broadspeed GT on this forum may still have some genuine aeg410 pumps . Shirley
1963 austin Cooper s mk1 1071
1966 Austin Cooper s mk1 1275
1968 Austin Cooper mk2 998
1962 Morris mini super 850
Porsche 997 turbo S
Ford transit van 280s.
I am from Essex
