My racer uses an original wiring loom... (type: Cooper S repro)
- Are the lights on a Mk1 Mini unfused?
From the wiring diagram in the old Haynes book it looks so... ? Is this what the in-line fuse (under the scuttlepanel) was later added to cure/help with?
- How much current (amp or watt) should be allocated for the ignition system (coil and points)
- Am I right in understanding the the wiper motor consumes about 14 watts?
Some swift replies would be very nice!
