Diff gear tab locks
Posted: Sun May 23, 2021 2:16 am
by bwaminispeed
Do people still use the tab locks on the diff bolts holding the crown wheel on......
I toss them and, use loctite......
Any thoughts, reasons for or against etc.....
Re: Diff gear tab locks
Posted: Sun May 23, 2021 3:47 am
The last ones I bought were soft, you could see them oozing out from under the bolt heads. All locktabs I've found the same, at least a few years back.
I've been using Loctite 243 on all these, the Damper Bolt, Cam Nut, etc - no issues and no intention to change. The key with any of these products is to get everything super clean before applying.
Posted: Sun May 23, 2021 4:10 am
by 850man
Please don't use loctite in engines & gearboxes. It is unnecessary and often a pain in the arse to get the bolt undone again when some poor mechanic has to fix something on your car.
I use the locktabs on the diff bolts. I am.yet to have an issue with "soft" locktabs.
Posted: Sun May 23, 2021 9:45 am
by MrNoo
Drill and lockwire.
Posted: Sun May 23, 2021 10:12 am
by Andrew1967
850man wrote: ↑Sun May 23, 2021 4:10 am
Agreed, use what the manufacturer intended and you can't go wrong. Appreciate that some new lock tabs aren't that good, but NOS ones are still quite easily available.
As for Loctite .. a certain gearbox god uses it on the 3rd motion shaft nut rather than a lock tab. I had the unfortunate job of removing it to sort the gearbox problems out .. what an absolute bastard it was. Ended having to warm up the Loctite to get the nut off and subsequently f***ed up a brand new double bearing
Posted: Sun May 23, 2021 10:54 am
by Peter Laidler
As Spider Chris alludes to, there are several types of the generic 'loctite'. And some are designed to cater for JUST the application we're talking about. The trouble is that the first thing we think about when we hear the word is '....what a bastard that is going to be.....' Just read the loktite data sheet (it's in the info part of the forum) and use the right sort. One in particular - forget all the numbers - eases off with just a quick blast of heat but will tighten up. So another blast and it's free!
I wonder how many gearbox builders or just enthusiastic amateurs have one single bottle or tube of loctite and use it for everything........
Or as I do, use loktite with the lock tab...., the tab acting as a washer and secondary locking medium. In the world of armour we used to use it as our friend and not a necessary evil
Posted: Sun May 23, 2021 12:49 pm
by GraemeC
Andrew1967 wrote: ↑Sun May 23, 2021 10:12 am
I have previously modified (shortened) the nut and used a first motion nut (IIRC) as a lock nut. Worked brilliantly.
Posted: Sun May 23, 2021 10:20 pm
As Peter touched on, there's a few different grades of locking compounds, most can be dismantled with normal tools, some are permanent, needing heat to release them. Like anything, use the right one for the application. I can't say I've ever had trouble disassembling anything I've assembled with loctite. I have however, found many many loose Flywheels and Harmonic Dampers over the years, that had been untouched since leaving the factory with locktabs.
Perhaps not a fair comparison here, but locktabs were dropped from mainstream production in the 60's and 70's by many other manufacturers and many took up with locking compounds, most being pre-applied to the new fasteners when purchased.
Posted: Mon May 24, 2021 8:46 am
by MiNiKiN
I basically use the lock-tabs for decorative purposes only. Loctite 243 (mid) will prevent loss of clamping torque. I avoid Loctite 277- as it requires loads of heat to enable disassembly.
Split washers, lock-tabs and serrated washers are not used any more for a reason - namely cause they don't work.
Only ones working:
Spring washer (needs very precisely applied correct tightening torque)
NordLockwashers.
Posted: Mon May 24, 2021 9:32 am
by GraemeC
MiNiKiN wrote: ↑Mon May 24, 2021 8:46 am
Only ones working:
NordLockwashers.
Schnorr washers are very good. Their only downside is you have to use the nearest metric equivalent on imperial fasteners.
Posted: Mon May 24, 2021 11:14 am
by Ronnie
If you must use additional locking these are used inside gas turbine combustion chambers Nord-Lock washers
https://www.nord-lock.com/shop/buy-here ... Buy%20Here available in imperial sizes.
But I would also like to add that in the late 60's early 70's GEC / Paxman (diesels) deleted all the castellated nuts, and split pins from the bottom end bolts of their high speed diesel's, indicating that if the fastener is properly tightened it should not come loose, they reviewed the tightening procedure, did away with the torque settings, and used bolt elongation measurements instead.
Posted: Mon May 24, 2021 3:02 pm
by MiNiKiN
GraemeC wrote: ↑Mon May 24, 2021 9:32 am
Only ones working:
NordLockwashers.
With "Spring washers", I actually meant them Schnorr washers - but their name didn't come to my mind.
