Another issue - banjo switch post too long?
Posted: Tue May 11, 2021 7:27 pm
by AndyPen
I am having fun with sorting out my front subframe brake lines here, now when I bolt in the the banjo switch post it doesn't go into the flexi pipe thread far enough!!! It bottoms out so the copper washers cannot be tightened up!!
Could I have been supplied the wrong brake pipes? They are the disc variant as this is an S.
Did I read somewhere that others have had this problem before and had to shorten the banjo post for the switch??? It does match the original length so what's going on here??? gggrrr
Re: Another issue - banjo switch post too long?
Posted: Tue May 11, 2021 7:34 pm
by JohnA
Check the depth of thread on the other hose in some braided kits they are different
Posted: Tue May 11, 2021 7:41 pm
by kit of bits
I’m sure I said to check thread depths?
You may have to cut a couple of threads off..
Posted: Tue May 11, 2021 7:46 pm
by AndyPen
Thanks, but these ones are rubber not braided???
They came from Somerford, so do I need to get another set from somewhere??
Posted: Tue May 11, 2021 7:48 pm
by AndyPen
kit of bits wrote: ↑Tue May 11, 2021 7:41 pm
I knew I'd seen it mentioned somewhere before - right under my eyes sorry!!
Posted: Tue May 11, 2021 8:10 pm
by kit of bits
Mine were rubber from mini mine, I didn’t notice till there was fluid poring out
Posted: Tue May 11, 2021 8:16 pm
by AndyPen
Your pain saved me - so at least a thank you for that.
Posted: Tue May 11, 2021 8:28 pm
by Herbert
That one just doesnt look right, have you tried one from another source ?
You can pack the washers, put two below, not just one. I will look in my cave, I think I have an original one. R
Posted: Tue May 11, 2021 8:37 pm
by Andrew1967
Might sound daft, but how thick are the copper washers that you are using .. although, just looked again and that one seems thick enough.
Shouldn't make any difference what type of brakes they are intended for as the fittings for the switch etc are all the same. Of course,it could be a depth of thread issue in the hose end which is nothing short of piss poor.
Posted: Tue May 11, 2021 9:16 pm
by AndyPen
The washers look the same as my old ones Andrew, and the banjo pin is identical as far as I can see. I may have the old cut offs of the brake pipes somewhere, they seem to be the culprit.
Posted: Tue May 11, 2021 9:27 pm
by Peter Laidler
Hope I'm not seeing this differently to the others but....... Maybe you could clean out the UNF thread in the hose with a 3rd-cut/ plug tap. I suspect that the thread just needs clearing out at the deepest part of it. Happened to me on the clutch hose as I recall.
Posted: Tue May 11, 2021 10:07 pm
by Andrew1967
That’s not a bad call Peter, certainly worth investigating.
Posted: Tue May 11, 2021 11:21 pm
by AndyPen
I'll certainly try that - thanks Peter.
Posted: Wed May 12, 2021 4:48 pm
by GraemeC
Andy is this having drum or disc brakes?
Posted: Wed May 12, 2021 6:49 pm
by Thorp
The hose doesn’t look deep enough. I did this exact job last summer and used hoses from Minispares which fitted perfectly.
Will see if I can find a pic
GBH249KIT
BRAKE HOSE CAR SET FOR DISC TYPE ONLY (saves over £4 )
Posted: Wed May 12, 2021 10:46 pm
by AndyPen
GraemeC wrote: ↑Wed May 12, 2021 4:48 pm
Discs Graeme, its the original dated 1071 subframe. Thorpe, rather than mess around I have just ordered some mini spares ones
Posted: Thu May 13, 2021 8:43 am
by GraemeC
AndyPen wrote: ↑Wed May 12, 2021 10:46 pm
Ah OK - I have some NOS Unipart drum brake ones spare but they'll be too short.
Posted: Thu May 13, 2021 1:04 pm
by AndyPen
That is so very kind, thank you for the thought Graeme
