Worn distributor.....choices??
Posted: Thu May 06, 2021 10:06 am
by davidmuir
Dizzy got a fair bit of slop in bushes........what are folks' opinions and suggestions of available replacements? (1380cc, big valve head, Piper 1BY etc).
Re: Worn distributor.....choices??
Posted: Thu May 06, 2021 10:40 am
by MiNiKiN
Send it to one of the dizzy-overhaulers for repair. AC Dodd (think he is more a modifier than overhauler) or
http://www.distributordoctor.com/
Posted: Thu May 06, 2021 11:06 am
by Peter Laidler
Having just looked at broken distributors in some depth, have you ever considered simply boring through the worn bearing and replacing it. On the other hand, could it be a worn main shaft - or both! But I suspect that being a match set that's been there since pontius was a pilot, they're both worn.
If it was me replacing the main casing bearing I'd simply machine out the old and insert one made from bronze. Ream to suit the shaft.
Posted: Thu May 06, 2021 2:12 pm
by Fanfaniracing
Hi David!
I fitted a Swiftune CSI electronic distributor on my 8 Port and i am more than satisfied.
alas bit expensive...
Posted: Thu May 06, 2021 2:13 pm
by bwaminispeed
From what I remember, it is a none standard size, which would entail making the reamer as well.......
In my experience, the bushes/shaft give very little problem......I have found, most of the slop is in the centrifugal advance mechanism (even brand new from the factory)......for which, I developed a an easy fix.....
I pull this apart, accurately drill (you need a lathe for this) the cam part to take a standard thinwall bronze guide liner, which also requires a few thou skim on the part of the shaft that it sits on........
This mod when carefully done, gives the advance mechanism pretty much zero slop, plus, being bronze on steel, basically never wears out......
Have never heard of anybody else doing this, but, it is much easier, and, gives overall better results than messing with the main shaft and bearings......
Posted: Thu May 06, 2021 5:21 pm
by davidmuir
ordered new vac. unit and will now investigate and consider the 'movement reduction' options.
Thanks, D
Posted: Thu May 06, 2021 6:57 pm
by Dearg1275
This from David Vizard’s book page 438 - 3rd edition of “Tuning the A series Engine”. Buy the book!
Much work!
Posted: Thu May 06, 2021 7:36 pm
by floormanager
I have my distributors rebuilt by the Distributor Doctor. First class service.
Posted: Thu May 06, 2021 10:24 pm
by AndyPen
floormanager wrote: ↑Thu May 06, 2021 7:36 pm
Me too - an excellent service.
