what is this seal?
Posted: Wed May 05, 2021 7:51 pm
by redrobbo
Was just having a nose on flea bay.
Anyone know what this is?
https://www.ebay.co.uk/itm/124706395343 ... SwvaNgMmbt
Re: what is this seal?
Posted: Wed May 05, 2021 9:08 pm
by AndyPen
No eye deer
Was wondering myself???
Posted: Wed May 05, 2021 9:18 pm
by Daz1968
Think it is the seal on the inner guards on very early cars,
Posted: Thu May 06, 2021 2:42 pm
As Daz says, inner wing mud deflector seal off early cars. Or that's what it claims to be.
Posted: Thu May 06, 2021 3:40 pm
by redrobbo
So does this seal run along the edge of the inner wing ?
if anyone got pictures of said seal then?
Posted: Thu May 06, 2021 3:53 pm
No, on these early cars there is a shield that goes on the back of the wheel arch that stops water & crap going down the back of the wheel arch, round the hinge area.
The clean part shows where the plate would go. the seal goes between the wing & the plate.
Posted: Fri May 07, 2021 9:20 am
by redrobbo
Well i've never heard or seen this shield before, you learn something everyday, thanks mk1
Posted: Fri May 07, 2021 9:29 am
Posted: Fri May 07, 2021 5:59 pm
by bwaminispeed
I believe those were a Dealer installed option, rather than an Early car feature........We had some in Canada......
Posted: Sat May 08, 2021 5:32 pm
by Peter Laidler
MGB's also had these shields fitted from new at the factory and as I recall, before paint. So you got the car, that had already started to rust behind the protective plate - that didn't fit particularly well in any case. Thereafter, road crap and shi......, er......, more salty crap got blasted around the edges and behind the protective plates until the inevitable happened. Yep...., the sills rusted out from the front and the rear of the front wings rusted out from halfway down the swage/join line.
I say it through gritted teeth but BMG/BL/Rover never learned. Even on the last Rover Mini, they were not painted under the top and bottom part of the boot or bonnet hinges. What a farce...........
Posted: Sun May 09, 2021 8:54 am
by 850man
"Body colour inner wheel arch guards (deflector plates) were factory fitted to all 59 cars from Morris chassis number 6481– Austin also introduced later, but no number change available but thought to be a similar number. Before this they were retro fitted via a service memorandum"
Our early 1961 CKD cars still had them here in Australia.
See here..
https://1959miniregister.com/variations-shell/
Posted: Sun May 09, 2021 2:20 pm
by redrobbo
Thanks for all the replies gents.
I have learnt something new, cheers
