Anyone have experience with these gaskets...pricy but may be a good product. Thinking of using one of the thicker items to reduce the CR.
Interested in hearing from those who have used them.
https://www.cometic.com/applications/au ... omper/1969
Cometic gaskets
- Has thanked: 8 times
- Been thanked: 22 times
- 850man
Re: Cometic gaskets
MLS head gaskets have been around for along time and are well proven.
But rather than using a thick gasket to try and lower the compression ratio, I would be increasing the size of the chamber.
Re: Cometic gaskets
I've used them on Normally aspirated 8 ports, i'm not sure if i will be ok or not on the boosted one?, they are supposed to be used on especially flat block surfaces (cant recall the technical term) but have been fine on my normally surfaced, re used blocks.
Caution
may contain 8 Ports, Xe's and VTec's, I don't do standard!
Caution
- Has thanked: 186 times
- Been thanked: 65 times
Re: Cometic gaskets
Good point.
Cometic specify a 50 Ra (USA Imperial Scale) finish, which is about on the cusp of what can be achieved on a conventional mill type surfacing machine in good condition and set up with a very fine feed rate, though normally you'd have them ground finished to achieve this type of Surface Finish.
Re: Cometic gaskets
Just use copper head gasket sealant and guarantee it will be fine. Believe Permatex sells it also. Machine shop here that builds high power motors uses Cometic with copper spray. Never a problem. And Cometic gaskets are reusable; with copper spray of course.
- 850man
Re: Cometic gaskets
No.Coolcat wrote: ↑Wed Mar 03, 2021 11:15 pm Just use copper head gasket sealant and guarantee it will be fine. Believe Permatex sells it also. Machine shop here that builds high power motors uses Cometic with copper spray. Never a problem. And Cometic gaskets are reusable; with copper spray of course.
MLS gaskets are designed to be used dry.
No sealent required.
