Boring out 998 primary gear for 1275
Posted: Sun Jan 31, 2021 11:27 pm
Hi all,
I’ve been thinking a lot about primary gears recently, as I need a 1275 pre A+ one (24 teeth), but only have smallbore pre A+ ones in my stock of parts. As far as I can think of it, the only difference is the size of the front bushing, which is in smallbore primary gears the same size as the rear/tophat bushing and in 1275 primary gears somewhat larger.
The question I’ve got in my mind now is: Can you take one of the smallbore gears and machine it to fit the larger bushing for the bigbore engines?
I know how to do the work holding and how to bore it out so that the bore stays concentric. But I reckon that the material of the primary gear is hardened and wonder how good or bad it is machinable?
Has someone here machined one in the past and can give me a hint to what tool is best to do the boring? What insert type works? Carbide? Or hard turning with PCD or CBN? Or does it need internal cylindrical grinding?
Cheers, Mike
Cheers, Mike
