Control and fuse box fixings
colonel mustard
Post by colonel mustard »
As per the title, is there anything special securing the control and fuse boxes in location? I have seen or heard of possibly a plastic captive but?
TIA
hanlminiman
Has thanked: 20 times
Been thanked: 34 times
Re: Control and fuse box fixings
Post by hanlminiman »
Check out the inner wing, by the bulkhead and also in front of where the flasher relay is fixed. There should be "holes." I did consider nylon fixings but used nuts and bolts to fix mine between diagonal strut and bulkhead. The main problem is the heater hose.
colonel mustard
Thanks Cliff
I have got the fuse box in and the heater hose (what a bugger that was!)
If there is no special plastic captive nut I will secure the control box with nuts and bolts. (Yes the 2no square holes seem to line up well)
GraemeC
Post by GraemeC »
These?
colonel mustard
Yep, they look like what I am after, any idea on a part number? Is it 21A305??
The fuse box has a smaller one of those plastic inserts.
colonel mustard
Thanks Andrew
I assume:
Control box require 2no 21A305
Fuse box require 1no GFK3428
Hope this is right ;)
GraemeC
Post by GraemeC »
For both Somerford shows GHF1030 (NLA, use 13H226)
Has thanked: 142 times
Been thanked: 122 times
These little square plastic fixing thinggies in various sizes are also available from BRESCO.com. Always good to keep handy too. Here's a tip for anyone rebuilding the front end of his/her mini. I used these plastic thinggies for EVERY application where a screwed self tapper went into the bodywork. The grille, grille parts, indicators etc etc. File the priginal holes square to suit the size plastic thinggy I was using before paint and that's it. No metal to metal contact ever again. Also did the same refitting the wheel spats on my Mini City
NZmember
Post by NZmember »
You're out!
Pedromintor
Post by Pedromintor »
welcome back
