Oil filter
Posted: Sun Jan 03, 2021 10:07 pm
by WesleyB
Hi
On what force (Nm) you put the bolt of the oil filter house ?
I did it with to many power and the seal was broken
Kind regards
Wesley
Re: Oil filter
Posted: Sun Jan 03, 2021 10:25 pm
by Polarsilver
are you sure the new top seal was fitted correctly in its position before you tighten up the filter canister Bolt ?.. and not to forget the lower seal positioned around the bolt ..just a light hand tight torque of the filter cannister bolt in my experiences is all that is needed .
Re: Oil filter
Posted: Sun Jan 03, 2021 10:30 pm
by WesleyB
Yes. I have order new seals and I do it again. Focus
Re: Oil filter
Posted: Sun Jan 03, 2021 11:17 pm
by Fanfaniracing
Wesley, what filter are you using? The spinn on GFE166 or the Filter element GFE103?
Or are you talking about the seal between the Filter housing and engine block?
Re: Oil filter
Posted: Mon Jan 04, 2021 6:57 am
by WesleyB
Hi
i have the GFE 103 paper filter.
Now I have order the new seals on the bolt and new filter and bigger seal on top
Kind regards
Wesley
Re: Oil filter
Posted: Mon Jan 04, 2021 8:17 am
by Simon776
BMC quote torque for the bolt as 10-15 lbs ft which isn't a lot and easily achievable with a short ring spanner - certainly well below the grunt scale.
Re: Oil filter
Posted: Mon Jan 04, 2021 9:15 am
by Terrapin-52
HI Wesley
please check the old seal is removed from the housing, if it has been in there for some time and crushed in the housing, it may not be to visible and the new seal could be fitted on top, with tightening it a little tighter and it will leak thinking it just needs to push up into the housing to seal
regards mike
Re: Oil filter
Posted: Mon Jan 04, 2021 9:46 am
by Old English White
I have never had a problem carrying out this simple task in the past but recently ordered some new filter elements and received them in dark blue and yellow boxes marked "CLASSIC GOLD" and using the old BL/UNIPART reference of GFE103. I found that the upper rubber seal split very easily and was lucky enough to have a spare one on the shelf. The material used for the seal in these new filters seems poor quality and I won't rush to buy more of this make.....
Maybe the filter in question was also this make?
Re: Oil filter
Posted: Mon Jan 04, 2021 9:05 pm
by Fanfaniracing
I Used always Minispares Oil filters. GFE103 and recently bought MSF103.
Also never had any issues with those filters.
Heard of some people having troubles but i think this were bad fitted.
Make sure you take the right of the 3 big O-Rings for the top and renew the two rubber seals of the canister if required.
And fit the spring, washers the right way!
Re: Oil filter
Posted: Mon Jan 04, 2021 9:18 pm
by floormanager
I had trouble sealing the bottom bolt - in the end I used a dowty washer which fixed it.
Re: Oil filter
Posted: Tue Jan 05, 2021 5:14 am
by TO THE FLOOR
I have had an oil trail behind me after changing the oil. Now I have gone to the spin on filter..Change the head then put oil on the gasket turn it until it touches then 3/4 (approx.) of a turn and your done, next time put oil on the filter and do it again. sorry if this is inappropriate.
Re: Oil filter
Posted: Tue Jan 05, 2021 6:11 am
by WesleyB
Hi,
thanks for the many replays. It is a easy job with a big story
Now I have order these
https://www.angloparts.com/nl/catalogue ... 63/011.130 and also some seals for the bolt.
Wednesday it is the delivery day
The one I had before was one of mini spares
cheers
Re: Oil filter
Posted: Sun Jan 08, 2023 12:07 am
by Tornado99
Sorry for resurrecting old thread, but I'm in Canada having trouble finding a compatible oil filter spin on type for a pre-injection 1275 MK3 mini. Rather not order from overseas for a low cost part when there should be compatible units locally from parts stores.
Locally FRAM, HiFlo, Purolator, Mann, K&N seem common on autostore shelves, but I need the cross reference/compatible parts numbers. My Haynes manual does not list the filter spec's.
Thanks.
Re: Oil filter
Posted: Sun Jan 08, 2023 12:35 am
by Terence
Tornado99 wrote: āSun Jan 08, 2023 12:07 am
Thanks.
My go to is the Napa Gold 1374
Re: Oil filter
Posted: Sun Jan 08, 2023 8:33 am
by Catmint
Thanks.
If you are still stuck, contact Dermot (360gts) on the forum and he should be able to help you in Canada
Re: Oil filter
Posted: Sun Jan 08, 2023 7:25 pm
by 360gts
Catmint wrote: āSun Jan 08, 2023 8:33 am
Thanks.
I happen to have a box of the Fram spin on filters.....can post within North America.
Re: Oil filter
Posted: Wed Jan 11, 2023 1:43 am
by Tornado99
I found the NAPA Gold 1374 filters at my local parts supplier. Pricey at $20 per, but I get 10% off with my auto club membership there.
Should be OK for another six months now.
Re: Oil filter
Posted: Wed Jan 11, 2023 6:26 pm
by Terence
Tornado99 wrote: āWed Jan 11, 2023 1:43 am
The K&Nās are both available at Canadian Tire and about the $20 mark, but have a slightly larger volume.
Glad you found some at Napa
Re: Oil filter
Posted: Fri Feb 03, 2023 1:28 am
by Tornado99
Terence wrote: āWed Jan 11, 2023 6:26 pm
I avoid K&N oil filters if they have the spot welded on nut. These have a long history of failing on both motorcycle and automotive versions....oil pressure rupturing the spot welds in such thin material or b/c or people using the nut for torquing up the filter initially. Unlike any other nut on your vehicle, this spot welded hex nut is supposed to only be used for removal of the filter....yet people will tend to use it like a normal thing. Poor design decision by K&N IMHO. There are many oil filter wrench solutions that are perfectly fine, why make this failure point for no real advantage...just sales & marketing hype.
