Flip cap removal
Posted: Sat Nov 14, 2020 11:58 am
by Aginley
Help wanted on how to remove this cap.
Wanting to do a nice restoration job on the planet rocker cover so need to remove the cap. I presumed it has a brass coller pressed in and the cap screwed onto the coller. I’ve tried to unscrew but it seams very tight
Don’t want to damage trying incase it’s not a screw in type.
Any advice appreciated
Re: Flip cap removal
Posted: Sat Nov 14, 2020 1:00 pm
by UHR850
WD40
Or try to heat it up a bit, maybe that will do the job
Kees
Posted: Sat Nov 14, 2020 2:05 pm
by Aginley
Is it a screw in type though? Not the whole thing pressed in?
Ta
Posted: Sat Nov 14, 2020 5:30 pm
by Oneball
I’ve got what looks the same both inside and outside on the Vette and it screws on.
Posted: Sun Nov 15, 2020 2:24 pm
by Aginley
Turns out it was a screw in! Just needed some heat!
Few hours of faffery later I’m very pleased with the results
Posted: Sun Nov 15, 2020 2:43 pm
by Time Bandit
That looks spot on, you've done a great job on it!
Posted: Sun Nov 15, 2020 2:45 pm
by colonel mustard
Hi Al
Did you mask the highlights off?
Posted: Sun Nov 15, 2020 4:10 pm
by Aginley
colonel mustard wrote: ↑Sun Nov 15, 2020 2:45 pm
Hi Al
Yes and used a scalpel to do the intricate bits. Took ages
Posted: Sun Nov 15, 2020 4:35 pm
by irlmin
Aginley wrote: ↑Sun Nov 15, 2020 4:10 pm
Hi Al
Was worth the effort I am sure , looks brilliant , G
