keeping slip joint rubbers supple
Posted: Mon Aug 24, 2020 9:45 am
by roger mcnab
hi how can keep the above mentioned rubbers soft and usable as these are from austin 1800 and are like hens teeth to find but these ones are still in good shape for their age
roger mcnab
Re: keeping slip joint rubbers supple
Posted: Mon Aug 24, 2020 9:49 am
If they are original manufacturer they are usually good for years. The problems arise with the after market ones.
Posted: Mon Aug 24, 2020 4:15 pm
by iain1967s
If you have old rubber parts which have hardened/shrunk but not cracked, try soaking them in a mix of 3 parts isopropyl alcohol to 1 part methyl salicylate for a week. Methyl salicylate is available by the liter from horse tack stockists, commonly known as Oil of Wintergreen.
The classic motorcycle guys use that recipe for the rubber concertina/bellows between the carbs and airbox, and I had similar success when I was rejuvenating the rubber seals on my Churchill hydrolastic pump.
I don't know how long the effect is good for, but it definitely works to make them supple again - at the expense of expanding the volume slightly, and making it smell like peppermint.
You can reportedly (I haven't tried) also use the highly concentrated 'homeopathic' version of Oil of Wintergreen, one 5ml teaspoon of oil to 300ml of water, to do the same job but in a matter of 5-10 minutes - but in that case you have to warm the water to get the reaction activated.
IMPORTANT: Concentrated methyl salicylate is highly toxic, so take adequate precautions.
Posted: Mon Aug 24, 2020 4:35 pm
by whistler
Glycerene from the chemists is good for reviving old rubber.
Posted: Tue Aug 25, 2020 9:30 am
by Jono
Gummi Pflege, if want a ready made product
Posted: Tue Aug 25, 2020 10:12 am
by roger mcnab
hi
i think these are original i have not tried to remove them from the drive shafts as yet maybe tomorrow if they are good i will put them in a safe place that i might remember where they are but while looking for them i could find the others that are in a safe place such fun
