Spi to Carb conversion
Brynmor
Post by Brynmor »
Now I know this isn’t the forum for more modern stuff, but has anyone on here done the above? And if so is it a difficult job?
Looking to do it to the Mighty Mini as it puts it into more tune able territory plus let’s me race with some other series.
hicklingmick
Re: Spi to Carb conversion
Post by hicklingmick »
Pedromintor
Post by Pedromintor »
yes i done it years ago. easy. change tank. put inlet and carb on . fuel pump. dizzy. i think it was much better on a carb. went well .cam suited being on carb. was sweet . Would do it again . thanks
peter
Brynmor
Post by Brynmor »
Thanks for replies, we’ll it’s got an alloy race tank plus facet pumps so that should negate some of that?
Did you also have to add choke cable etc I guess?
Pedromintor
yes added choke
jayare
Post by jayare »
Your fuel pumps will probably be too high a pressure for a carb so will either need swapping to something more suitable or at the very least will need a regulator to bring the pressure down to about 3-4psi,
JR
