Does anyone know where I can get an original style 13 row oil cooler with mounts on the bottom only ?
The ones that I've seen on sale have mounting flanges on the top and bottom.
I dont think the two flange type will fit in the original location - could be wrong but it looks pretty tight in there.
Is it just a case of grinding the top flanges off ?
Oil Cooler
Re: Oil Cooler
Dont grind them off, make 4 long Alloy tubes, that you push in between the brackets.
Then get one of these metal pins with thread on, and make some long bolts.
I used locking nuts in one end, this way your oil cooler is boltet on, using both brackets.
That way it wont break in the joints, becourse the hoses pull/push at the top.
Re: Oil Cooler
If appearance is really important to you, the ends can be cut from the top plate without hurting the cooler. A photo of the cooler is attached, not great but you might be able to get the idea.
Regards
Al
Regards
Al
- Vegard
Re: Oil Cooler
On another note, if you need a 13 row oil cooler, you obviously race in very hot weather...
Re: Oil Cooler
No racing for me - well, not hat car anyway.
Just been caught with the 'originality bug'.
If anyone has a vacine/cure for it please let me know - its costing me a fortune
- pad4
- Vegard
