Hiya this is my 3rd project mini she not as bad she she looks unfortunately she been reshelled with a mk2 shell but will be converted to a mk1 ill let the pics do all the talking
that my lil bro in the pics
this project will start after my estate is done and the panels on front are just balancing on lol
anyone know what this means ????
if anyone has a mk1 shell ild love to buy it as ild rather buy a mk1 shell than convert this mk2 copper s shell to a mk1 would be such a shame
danny
mk1 1962 super deluxe project
Re: mk1 1962 super deluxe project
Are you sure it is a Mk2 Cooper S shell? I can't see any evidence of the boot board brackets although the rear bulkhead shots are too dark to tell. Also there is no RH tank stand. I would need someone more knowledgeable to confirm this, but the only other thing I can think of checking is whether it has the servo mounting holes in the RH inner wing, and the control box mounting holes next to the cross member, I'm just not sure if all cars had them or not. As it has no front panel it is impossible to tell from that.
It looks like a very savable car though but it is certainly a lot of work. Good luck with it, I look forward to seeing your progress.
Austin Cooper wrote:Are you sure it is a Mk2 Cooper S shell? I can't see any evidence of the boot board brackets although the rear bulkhead shots are too dark to tell. Also there is no RH tank stand. I would need someone more knowledgeable to confirm this, but the only other thing I can think of checking is whether it has the servo mounting holes in the RH inner wing, and the control box mounting holes next to the cross member, I'm just not sure if all cars had them or not. As it has no front panel it is impossible to tell from that.
Thanks im sure if it a genuine mk2 copper s shell from the points you said but tger bloke the shell originally came from did you use it for a mk2 cooper s he might have been reshelling it with this made to look like 1 but ya she saveable just gotta finish ky 1979 Clubman estate and got another 1991 city that needs doing just takes me ages as im only 18 and moneys tight with collage as well
Danny
