powerlite starter- re routing
Posted: Tue Jul 21, 2020 7:17 pm
For those who have some experience of powerlite stsrter motors...
I've been advised by powerlite to utilise the built in solenoid, or at least try it....currently its wired using my worksy type push button solenoid..
It should be relatively straightforward but I thought I'd better check first...the idea is that the onboard solenoid needs direct 12v from battery, and a trigger wire into separate connector that it has. I want to use my push button to start...
Is my diagram correct, or am I missing something?
