Vortz Airbox
Thorp
Vortz Airbox
Post by Thorp »
Morning,
Bit of a long shot, but does anyone know if it’s possible to obtain new Vortz airboxes for twin HS4’s? I know up until a few years ago it was possible but I cannot find contact details.
Terence
Re: Vortz Airbox
Post by Terence »
111Robin
Re: Vortz Airbox
Post by 111Robin »
The HS2 airbox can be modified to fit. Needs spacers between elbows and carburettors so the dash pots clear the box and the depth of the box reduced to clear the bulkhead. Problem is the price of air boxes these days, cutting them up seems like sacrilege.
Image20200218_214026 by Robin Derrick, on Flickr
Thorp
Re: Vortz Airbox
Post by Thorp »
Thanks both. I’m just trying to find a solution to cut down the noise of induction roar as currently running ram pipes and filter socks which sound great but get a bit wearing on longer drives.
The Vortz box (or something similar) looks like a solution without denting performance; searching through the forum Pad4 had one made a number of years ago; is he still active on here ?
Failing that, perhaps chopping an HS2 box is the solution.
Oneball
Re: Vortz Airbox
Post by Oneball »
I’ve used Concept Racing for bits in the past. They could easily make you one, probably coat no more than a Vortz one.
https://www.conceptracing.co.uk
Fanfaniracing
Re: Vortz Airbox
Post by Fanfaniracing »
If someone has the dimensions i can easy make some if there is any interest...
camshaft2
Re: Vortz Airbox
Post by camshaft2 »
I’d be interested in one if it would fit my standard twin HS2’s....
Minigman
Has thanked: 5 times
Re: Vortz Airbox
Post by Minigman »
I’d be interested also.
- You must have shot an awful lot of tigers, Sir.
- Yes, I used a machine gun ;)
irlmin
Has thanked: 12 times
Re: Vortz Airbox
Post by irlmin »
Interested as well, for twin H4s. G
rpb203
Re: Vortz Airbox
Post by rpb203 »
Fabian, I would be interested in one if it does HS4's.
Gary
Fanfaniracing
Re: Vortz Airbox
If someone has the dimensions i will make some. Or i can make a prototype wich look's like...
almondgreen
Re: Vortz Airbox
Post by almondgreen »
I have the dimensions somewhere.....
mini_surfari
Re: Vortz Airbox
Post by mini_surfari »
also interested in one for a pair of hs4's
Fanfaniracing
Re: Vortz Airbox
Still waiting if someone has the dimensions of the Vortz Airbox...
panda911
Re: Vortz Airbox
Post by panda911 »
Hello.
I have been chasing leads to buy a Vortz airbox for my HS4 carbs.
At moment running on H4 carbs with highly modded HS2 pair box.
Because of the mods to allow HS2 pair box to fit over the H4 carbs, the induction roar is
unacceptable.
I have seen on this thread the HS4 carbs with a modded standard twin airbox .
Looks an elegant solution and am more than happy to settle for that if someone will make it, then I will pay.
I will follow up leads already given and have one more lead for Vortz.
Life is a bit short to continue the chase.
BR
P
W1NG3D
Re: Vortz Airbox
Post by W1NG3D »
Specialist Components now make a Vortz-style airbox for twin HS4s, I believe they were also working on a version to fit HS2s. Expensive, but they do look good. https://www.specialist-components.co.uk ... irbox.html
swifty
Re: Vortz Airbox
Post by swifty »
I’ve driven a vortz mini and to me there is a louder induction roar from the air box over standard . Part of the appeal , it sounds like it’s doing its job of sucking in lots of air . … Shirley
1963 austin Cooper s mk1 1071
1966 Austin Cooper s mk1 1275
1968 Austin Cooper mk2 998
1962 Morris mini super 850
Porsche 997 turbo S
Ford transit van 280s.
I am from Essex
