Page 1 of 2
Cost to line bore mains....
Posted: Mon May 25, 2020 6:21 pm
by Exminiman
Just got price of £260 plus VAT to line bore, three steel main caps.....
Does this sound right ? Seems bit high, even for “Darn Sarf” ...
Or am i just being tight :D
Re: Cost to line bore mains....
Posted: Mon May 25, 2020 7:25 pm
by LuisM
well, and we complain here in PT when we are asked for 120 euros to do same job! :o
Regards
Luis
Posted: Mon May 25, 2020 7:37 pm
by GraemeC
As I learnt, if it is someone that knows what they’re doing, it also depends on whose steel caps you’re intending to use. Some need more passes than others and hence cost more
Posted: Mon May 25, 2020 7:48 pm
by Herbert
Its a little bit dear. I had mine done by a Mini7 engine builder and he just wanted £150
Posted: Tue May 26, 2020 6:36 pm
by Exminiman
Cheers for the comments, i thought £260 was a bit on the dear side.....
Time to get some other prices.........me thinks...any recommendations within 25 miles Reading?
Classic And Modern get thumbs up from Rae Davis .... http://cmesuk.com/
Posted: Tue May 26, 2020 8:53 pm
by agricola
even though I'm in Yorkshire it would always be Scholars in Suffolk.
They line honed my s block
Posted: Tue May 26, 2020 9:40 pm
by Exminiman
agricola wrote: Tue May 26, 2020 8:53 pm even though I'm in Yorkshire it would always be Scholars in Suffolk.
http://www.scholarengines.com/
Not heard of them before, thanks for recommendation, can you remember the cost? It s not everything, just interested to see how much variation there is
Posted: Tue May 26, 2020 10:46 pm
by Lakeland997
Exminiman wrote: Tue May 26, 2020 9:40 pm
If a Yorkshireman went all the way to Suffolk, it must be cheap :D
Posted: Wed May 27, 2020 6:20 am
by OzOAP
Does the machine shop know what size the caps are supplied at?
Swiftune ones are a lot closer to finished size than MED.
Gosnays in Romford charged nearly double to do MED caps, normal price was £185 to do Swifty ones.
The money saved buying the cheaper MED caps was false economy...lesson learnt.
Posted: Wed May 27, 2020 8:36 am
by Charlynsane
In France then just refuse to make it.. or for 600 pounds..
Posted: Wed May 27, 2020 9:07 am
by 251 ENG
If your having a block line bored with steel caps you want somebody that will do it correctly and in tolerance , not looking for the cheapest job .
Posted: Wed May 27, 2020 10:09 am
by Polarsilver
251 Eng gets my vote to become a Specialist Adviser .. cos he actually knows what he is talking about ;)
Posted: Wed May 27, 2020 3:24 pm
by johnv
cmesuk did mine along with lots of other work on various engines, they're very good
Posted: Wed May 27, 2020 5:16 pm
by Exminiman
OzOAP wrote: Wed May 27, 2020 6:20 am Does the machine shop know what size the caps are supplied at?
I am having to get them from Sprite Mania, as it an early thin flange block with odd size mains dowels....so not sure, how much.....
Posted: Wed May 27, 2020 5:21 pm
by Exminiman
251 ENG wrote: Wed May 27, 2020 9:07 am If your having a block line bored with steel caps you want somebody that will do it correctly and in tolerance , not looking for the cheapest job .
Thanks for advice, not looking for cheapest over quality, but its not something I have done every day, trying to get a feel for how much prices and quality varied and maybe some recommendations
Posted: Wed May 27, 2020 7:25 pm
by Hipwell
This, £260 is well spent if the job has been completed perfectly.
There is also a massive difference between line boring a block with new caps to whistling through aN existing block with a line honer.
Posted: Wed May 27, 2020 7:31 pm
by Supersonic
My friend line bored a block and fitted new big end / mains bearings at a cost of £170 :D :D
Alan
Posted: Wed May 27, 2020 7:41 pm
by Supersonic
Polarsilver wrote: Wed May 27, 2020 10:09 am 251 Eng gets my vote to become a Specialist Adviser .. cos he actually knows what he is talking about ;)
Norman, hope you are keeping well? Without any doubt 25 Eng and Elgin Greer have my vote 100%. The cost above was a mates rate. :D
Alan
Posted: Thu May 28, 2020 10:37 am
by agricola
Scholar dont work cheap but do give value for money. I have dealt with them for 30 years and Alan Wardropper is a friend but that's not why I use them. I find there work consistently of a high standard, when an engine arrives its properly finished off. I am especially pleased with the restoration of my 1970 andy barton S engine which they did. They were/are best known for Kent Formula ford building so know engine machining backwards. But they do all makes and actually have quite a depth of experience with a series and did my fia mini heads part cnc finishing by hand and flow tested against competitors. I am sure there are plenty of other good engine shops about and normally its a personal choice.
Posted: Thu May 28, 2020 4:27 pm
by YMJ
Classic example of a bloke copying something without measuring or examining properly
