Speedo rebuild
Posted: Fri Jun 24, 2011 7:47 am
by rolesyboy
Hi All. I have aquired pile of bits which includes a 120 S speedo. The back case is rusty and I do have a 'Super' type speedo ie 90mph which I would like to use for spares. Is rebuilding yourself realistic or is it an impossible job? I imagine it is fairly straightforward if done methodically and carefully but I would welcome any tips or advise on any parts that are not interchangable. The other question is can I retain the lions share of my 90mph speedo and just bolt on the S bits to make life easier? Thanks.
Re: Speedo rebuild
Posted: Fri Jun 24, 2011 12:11 pm
by abri
Aren't there differences in the distribution of lights around the face between these two speedos?
Either way, I am very interested in this same topic because I have a 120mph speedo with a stuck odometer....and I also have a fairly new 90mph speedo from a late '64 Austin Mini 850. So I'm planning a similar operation. I would have thought one could try and swap the odometer bits around but I haven't taken it apart in a long time, so I'd have to check the details.
Re: Speedo rebuild
Posted: Sat Jun 25, 2011 9:14 am
by nick rogers
Don't canibalise a Super speedo! They are rarer than 120 ones. Use any other 90 speedo that was used with the same final drive as the S. This can be determined by the 4 digit revs per mile figure on the speedo face.
Re: Speedo rebuild
Posted: Mon Jun 27, 2011 10:58 am
by rolesyboy
Hi Nick. Thanks for your reply. Don't suppose you know what serial numbers I should look for. I don't have a clue. Is it based on the 4417/00 or 4417/18 figures? Cheers. Mark
PS If you don't reply within 24 hours the 'Super' speedo gets it.......
Re: Speedo rebuild
Posted: Mon Jun 27, 2011 8:41 pm
by nick rogers
OK. OK. Put down that hammer ! The 3.76 final drive would have 1376 and the 3.4 would have 1280 as the RPM figures. The Super was 3.765 but it was on cross plies so would have 1408.
BTW, the Super speedo is rare because it's the only black 90 mph with only 5 digits on the odometer.
(unless anyone knows differently).
