1275 pressed steel Rocker Pad Q,s
Posted: Sun May 24, 2020 10:48 am
Have a set of 1275 Pressed Steel "Large oval Pad" Rockers that probably came from a Mk3 S Engine..
Question.. can these Rocker "Contact Pads" be resurfaced to take out evident wear on the Rocker Pad to Valve contact area ?
Second Question..How deep is the case harden on these Rocker Pads ?
Third Question ..Maybe the Pad itself is made from a Tool Steel type material that did not get or need any Case Hard Surface Treatment ?
Forth Question.. Pad surface profile needs to be correct on any re-grind .. who does this task in the UK?
Fifth Question .. Why do the later type Rockers of Pressed Steel type need to have a Large Oval rocker Pad?
i learn something new everyday
