Wiper Issue advice needed
Posted: Wed Apr 22, 2020 11:48 am
My issue .. the Windscreen Wipers work ..BUT only when "One" Wiper Blade is Fitted.. when both Wiper Blades are Fitted the Wipers Stop working due to dry drag on the screen Me-thinks?.. Investigation i then remove both blades & the Wiper Motor Cover .. then start the Motor & all seems to work ok the motor turns & both wheel boxes work as i expected.
My Wiper drive system has new MS supplied Wheel Boxes along with a nos OE Drive Cable & i have a refurb; DR3 Wiper Motor from a forum member.. the wiper drive system seems to be working all ok that is until both Wiper Blades are in use?
Without a good solution my next action is take out with the inside car Dash Trim & remove the Wiper assembly then run it outside the car, but will i then find the problem ?.. your advice & experience is needed.. many thanks.
