My name is Daniel, I live over in The Netherlands but with Yorkshire heritage, and I'm restoring a 1975 Innocenti Cooper 1300 Export. For those who don't know them, they were Minis built in Italy by Innocenti in Lambrate near Milan. Initially they were built from CKD kits sent over by BMC, however by the time the 1300 Export came along they had replaced a lot of panels with their own pressings. Despite the Mk3 Cooper S ending production in the UK by the early 70s to make way for the 1275GT, BMC still had a contract with John Cooper. In order to satisfy the terms of the license agreement BMC continued the production of Coopers in Italy with initially the Innocenti Cooper 1300 followed by the Cooper 1300 Export. The Export being a touch more luxurious than the pre-export model, both being significantly more luxurious than their UK cousins. Most notably the 6 dial dashboard, quarterlights in the doors, internal bonnet release, and a whole host of other things.
I had been on the lookout for one of these for a while and the right one never seemed to come around, until I saw a project advertised on the club website. After a few emails and a trip across the country to see the car a deal was done and I went back a week later with a van to pick up my Inno. It's an original Dutch market car and came replete with a spare 850 engine which the owner had dropped in when the 1300 unit started using about as much oil as petrol, an extra gearbox, a few UK bootlids and doors, and boxes and boxes of bits. It was in a bit of a state when I picked it up but it came with all the panels it needed included in the sale.
This was taken when we arrived back at the workshop, my dad stood next to me who has been as he calls it "supervising" on this project.
The APK (our MOT) expired back in 1995 and I guess that's when it was taken off the road. The previous owner had replaced the floor but it was very rough. None of the welds had been ground down and it was tetanus city. The inner wings (still original with the VIN stamped on it) still had bits of front wing on it where it had been spotwelded. So the first job once we got it installed in the shop was to tidy up the shell.
After pulling the flywheel and removing the transferhousing I put the 1300 Engine up on the stand. Though the cars were called Cooper, production of 1275 S blocks had already ceased, so these got a version of the 1300GT block with a 12G1805 Mk3 S head and the AEG510 Cooper S cam.
Going by the previous owner's report it was more than a bit tired. A quick look at the pistons revealed that it had in the past already been bored +20thou once in it's life. The engine tag showing 719X, indicating it's an original Innocenti engine.
WIth the engine up on the stand I could then split the box easily and strip it right down to the casting. The crank looked a bit worn but not too badly. The whole lot then went to an engine builder and machineshop in The Hague I had recommended by a friend. They gave the whole lot a chemical strip, polished the crank for me (amazingly it didn't need regrinding according to them), polished the cam, decked the block (they reckoned it had slightly warped), skimmed the head, fitted hardened valve seats, lapped in the valves, fitted new bearing shells, bored and honed it up to +40 and fitted new 21253 pistons, and it came back to me quite a while later like this.
While that was away the bodywork pressed on. As I was cleaning up the PO's work it became clear it need a bit more surgery than I could provide as it had had some dodgy repairs in the past. So off it went next door to my good friend and next door neighbour in the workshop Mr Ben Konst (who some of you may know, he was importer of Peel Viking Sports back in the day and is well known in Healey circles). He might be pushing 80 now, but he is still a wizard with sheetmetal and sharp as a tack (even if a bit stubborn). We also discovered the car had at some point in it's life off the road been stored on it's roof, probably on a roofrack and it had bent the roof gutters to high heaven.
The rear quarter had been poorly patched in the past and it was completely the wrong shape.
So out it came
Patched up and skimmed with filler
The doorstep also needed repairs as it was a patchwork of different layers.
Front end in red oxide and new front wing offered up for scuttle repair
Ben also made me a new parcel shelf as the old one was mostly holes for big speakers
The doors got fresh Heritage skins as the old ones were very rusty
The new floor (fitted by PO) was stripped, painted in red oxide and then seam sealed
We also found holes for aerials all over the car (I think we found at least 3) which were all filled in with fresh metal as I will not be fitting a radio
A new scuttle repair piece was made
[img[https://i.imgur.com/WWSGMMq.jpg[/img]
And the whole front end clamped up
Sadly, the numberplate brackets aren't Inno Spec, but I didn't manage to convince Ben they needed changing (told you he was stubborn), and to be honest, when you mount the plate, who will know except for the real anoraks; so at the end of the day I can't be too sad about it.
You may notice by this time the engine bay is already in body colour, we had a part of the inside of the old doorskin measured for colour and painted the insides with that.
This post is probably long enough for now. Next time adding some NOS Inno bits and gearbox overhaul.
