Crank Seal Guard?
Posted: Tue May 31, 2011 9:37 pm
by tomkidd
How do folks, just been looking at the Keeping Your Mini Alive magazine and it shows a crank seal guard that sits onto the teeth of the primary gear, to protect the red oil seal that goes into the transfer case.
I can't see it online anywhere? The magazine suggests that you must fit it... if only I had one I would!
Re: Crank Seal Guard?
Posted: Tue May 31, 2011 10:06 pm
by InimiaD
Do you mean one of these Tom.?
http://minispares.com/Product.aspx?ty=p ... 654&title=
The sleeve is the one on the left.
When I didn't have one of those I used to wrap some masking tape round the primary gear splines then use a feeler gauge blade to gently tease the seal over the back of the gear whilst gently shoving the outer edge of the seal at the same time. Worked a treat.
Apologies for the blatant advertising. :)
Posted: Tue May 31, 2011 10:14 pm
by tomkidd
THanks, I know of that tool but this thing is like a disc that sits over the crank oil seal... after you have fitted the seal
Posted: Wed Jun 01, 2011 12:09 am
by Smiffy
They where only standard fitment on verto engines, it's a plastic protecter/oil flinger. Part No.DAM2821, no longer available. But I'm sure I saw in one of the comic's, somebody has started producing 'em again.
Posted: Wed Jun 01, 2011 8:47 am
by tomkidd
Cheers Smiffy
Posted: Wed Jun 01, 2011 9:04 am
by guru_1071
never been out of stock....... ;)
Posted: Wed Jun 01, 2011 9:27 pm
by sandman
As seen here:
Posted: Thu Jun 02, 2011 12:17 am
by graham in aus
Jeez Ed, what happened in there!
Looks like a bomb went off! :lol:
Did the plastic thing protect the seal from the shrapnel!! :shock:
