wiring problem
Posted: Wed May 11, 2011 6:10 pm
by jamesnutter50
I seam to have electrical gremlins in my car. I go in the car and everything works. next time the lights are not working. and then they work but no indicators etc
Any ideas what i need to do to get them working ?
were are all the earth points ?
Regards
James
Re: wiring problem
Posted: Wed May 11, 2011 8:07 pm
by IAIN
Check the spade connectors connecting to the fuse box are'nt corroded or loose. Also check the fuse box spring connectors, holding the fuses tight and clean. :idea:
The earth is on the bulkhead cross member by the angled bracket/inner wing brace. ( unlikely to be the problem )
Re: wiring problem
Posted: Wed May 11, 2011 8:14 pm
by InimiaD
Also check the Block connector tucked up under the slam panel.
