S Drive Shafts?
Posted: Thu Jul 15, 2010 6:54 am
by graham in aus
I have always believed that S driveshafts have the raised ridge in them, like the two centre ones here?
Also, compared to the non S ones either side, the S ones are a bit shorter? is that correct?
I always though the shafts were all the same length?
Cheers! 8-)
Re: S Drive Shafts?
Posted: Fri Jul 16, 2010 12:54 am
by graham in aus
Hmmmn.... Tumble weed rolls across the thread! ;)
Anyone care to confirm these as S driveshafts?
:geek:
Re: S Drive Shafts?
Posted: Fri Jul 16, 2010 3:00 am
by MadMatt
yep, dead right Graham
as in the "S" shafts had the raised lumps & are a tad shorter
Re: S Drive Shafts?
Posted: Fri Jul 16, 2010 4:05 am
by graham in aus
Aah you can always rely on a goodfernuttinlazyassmountainbikinsurfinfreakinMiniMechanic!
I guess a bit shorter 'cause of the general differences / positioning with Hardy spicers, different hub (vs Drum) etc.
Cheers Matt! 8-)
Re: S Drive Shafts?
Posted: Fri Jul 16, 2010 8:06 am
Hi Graham,
I read your post yesterday but didn't comment cos I didn't know. The "S" shafts came out in 66 & I have never had a car as late as that.
Thanks for teaching me something, if nothing else.
Re: S Drive Shafts?
Posted: Fri Jul 16, 2010 9:23 am
by Toby
The ones with the raised ridge on them are later shafts, the earlier ones used on cars with rubber couplings don't have these markings, regarding the length I would have to check.
Re: S Drive Shafts?
Posted: Fri Jul 16, 2010 9:29 am
by guru_1071
i was always lead to believe that the bump is on the shaft to stop the hardy spicer going over centre when the suspension is at full droop - the bump rubs on the suspension pin and acts like a crude stop
Re: S Drive Shafts?
Posted: Fri Jul 16, 2010 11:04 am
by graham in aus
guru_1071 wrote:i was always lead to believe that the bump is on the shaft to stop the hardy spicer going over centre when the suspension is at full droop - the bump rubs on the suspension pin and acts like a crude stop
Really? now that's interesting! or is my leg being pulled? Sounds a bit agricultural even for BMC! :mrgreen:
Re: S Drive Shafts?
Posted: Fri Jul 16, 2010 8:33 pm
by sandman
Are these shafts found on the autos too ? (should be if the hump is to limit travel - yes?)
Also - any other difference on these shafts? Are they stronger? Better steel etc?
