Re: juddering clutch on early oil fed primary gear car- grrr
Posted: Thu May 05, 2011 8:04 pm
by InimiaD
Yes it is possible to change the seal insitu, but you'll need the correct Primary gear puller, sleeve and Oil seal replacement thingummyjig to do the job correctly so the Oil seal goes on straight.
Posted: Thu May 05, 2011 10:14 pm
by InimiaD
"seal puller"
The primary gear puller pulls the gear and takes the oil seal off with it.
Primary gear puller. The C shaped item of the three.
It's a while since I used it in anger, but i think the flywheel puller boss is used in conjunction with the C puller.
The black tube is the protective sleeve and the silver tube is used to press the oil seal back into place squarely.
Posted: Fri May 06, 2011 1:59 pm
by ace01
What about the flywheel oil seal on the oil fed primary set up?
Posted: Fri May 06, 2011 2:04 pm
by guru_1071
ace01 wrote:What about the flywheel oil seal on the oil fed primary set up?
doesnt one from a wheel bearing kit fit, or have i dreamt that up?
Posted: Mon May 09, 2011 12:45 pm
by ace01
guru_1071 wrote:ace01 wrote:What about the flywheel oil seal on the oil fed primary set up?
No, I think you're right on that.
