Boot wiring
Posted: Tue Apr 02, 2019 6:52 pm
by 5portsrock
Hi does anyone have a picture of how the boot loom runs? Many thanks.
Re: Boot wiring
Posted: Tue Apr 02, 2019 7:36 pm
by DUF2 ‘65 Elf
Could do with this myself, I need to know which way the loom runs around the tank.
Re: Boot wiring
Posted: Tue Apr 02, 2019 7:48 pm
by Daz1968
Don’t have a picture, but it’s pretty easy, loom comes down lh rear pillar into boot area, loom splits, fuel pump and gauge run down tabs on bulkhead, gauge to gauge, pump wiring through hole in floor with grommet, then rest run to lh rear light and earth connection fits to rear panel, then it runs around hinge panel to rh light held in place by tabs, there is a connection near tank that connects to the wiring to the rear number plate lamp,
Hope all that makes sense
Re: Boot wiring
Posted: Fri Apr 12, 2019 10:16 am
by AndyPen
Daz1968 wrote:Don’t have a picture, but it’s pretty easy, loom comes down lh rear pillar into boot area, loom splits, fuel pump and gauge run down tabs on bulkhead, gauge to gauge, pump wiring through hole in floor with grommet, then rest run to lh rear light and earth connection fits to rear panel, then it runs around hinge panel to rh light held in place by tabs, there is a connection near tank that connects to the wiring to the rear number plate lamp,
Maybe this pic of the visible bits will help? Late 64 Hydro. Note that some early hydro cars had wiring for both 6 screw and twist and turn fuel tank types by the way.
Re: Boot wiring
Posted: Fri Apr 12, 2019 2:00 pm
by dklawson
Is that jute in the boot picture? Was that common? When I got my car all it had on the boot floor was rust.
Re: Boot wiring
Posted: Sat Apr 13, 2019 7:02 pm
by LarryLebel
Doug. AFAIK the jute pad is standard fitment. It doesn't do much good, other than hide the rust you mentioned, like all the other jute padding in a Mini.
Re: Boot wiring
Posted: Sun Apr 14, 2019 12:07 am
by AndyPen
dklawson wrote:Is that jute in the boot picture? Was that common? When I got my car all it had on the boot floor was rust.
Been nattering about it over here ;-)
viewtopic.php?f=3&t=24939
Re: Boot wiring
Posted: Sat Jul 31, 2021 9:57 pm
by rogerotto66s
Daz1968 wrote: Tue Apr 02, 2019 7:48 pm ... earth connection fits to rear panel...
I would appreciate some clarification.
The only bolts nearby are the boot hinge, tank strap, subframe mount.
I was going to opt for the boot hinge since the tank is not in place yet and I did not want to undo the subframe bolt.
Re: Boot wiring
Posted: Sat Jul 31, 2021 11:52 pm
by Ronnie
I would suggest the tank strap, the same as the picture above but any good earth to the body clean any paint off. :)
Re: Boot wiring
Posted: Sun Aug 01, 2021 1:54 pm
by rogerotto66s
I did not notice the ground going to the tank strap in the AndyPen picture above.
It thought it was going to the rear panel.
Thanks for pointing that out.
Re: Boot wiring
Posted: Mon Aug 02, 2021 6:31 pm
by Peter Laidler
Just been into the boot of both my S's and the earth wire with the ring terminal shown in Rogers photo is earthed to the body of the car by one of the 4BA (?) bolts used to retain the rear light to the car.. There's a star washer below and above the terminal to give a good earth
Re: Boot wiring
Posted: Mon Aug 02, 2021 10:10 pm
by rogerotto66s
Thanks Peter.
My nut is quite unusual! Only one I have seen on my mini so far!
Seems it is a Tinnerman lock nut washer screw!
Here is a picture of my ground wire attachment and the tinnerman nut.
My “S” is a July 1966 build date.
Re: Boot wiring
Posted: Wed Sep 22, 2021 1:02 am
by rogerotto66s
Just came across this posted in another topic.
Re: Boot wiring
Posted: Wed Sep 22, 2021 8:33 pm
by AndyPen
Just checked one of my other cars today, late 64 is earthed through the tank strap on that one too... but any good earthing point will do.
