Speedwell Rev-Counter
Posted: Wed Dec 05, 2018 5:53 pm
by jsilv
Anyone knows how to connect this Speedwell Rev-counter?? :D
Thanks,
Re: Speedwell Rev-Counter
Posted: Thu Dec 06, 2018 8:39 am
I don't have the details for those late ones.
Sorry,
Posted: Thu Dec 06, 2018 1:02 pm
by jsilv
mk1 wrote:I don't have the details for those late ones.
Sorry,
Thanks, so this a late version, it has 2 wires connection :roll:
Posted: Thu Dec 06, 2018 1:46 pm
It's a very late one.
Were still available new in the 80's.
Posted: Thu Dec 06, 2018 5:14 pm
by jsilv
mk1 wrote:It's a very late one.
Sourcing in the internet, the only that uses 2 wires connection. :?
Posted: Fri Dec 07, 2018 7:59 pm
by jsilv
Any ideas? Anyone using one? otherwise is useless... :cry:
Posted: Fri Dec 07, 2018 8:28 pm
by iain1967s
Is it sealed, or can you dismantle to separate the gauge from the pod?
More might be learned from photos of the internal layout and design.
Posted: Fri Dec 07, 2018 8:40 pm
by Exminiman
Think you just put in inline on the positive coil wire, you will then see if it works or not :?
Posted: Fri Dec 07, 2018 10:33 pm
by jsilv
iain1967s wrote:Is it sealed, or can you dismantle to separate the gauge from the pod?
It is sealed... i never saw one with only 2 wires, unless it uses the back metal support, as ground... :?
Posted: Fri Dec 07, 2018 10:52 pm
by jsilv
Exminiman wrote:Think you just put in inline on the positive coil wire, you will then see if it works or not :?
It could be, with back metal support as ground, who knows??? :cry: :?
Posted: Fri Dec 07, 2018 11:34 pm
by Exminiman
In your first picture there is a two bladed connector attached to the body, this is most likley the earth.
Just wondering if the counter has a light and is so where is the bulb holder
Posted: Fri Dec 07, 2018 11:42 pm
by jsilv
Exminiman wrote:In your first picture there is a two bladed connector attached to the body, this is most likley the earth.
The two bladed connector is the bulb holder for the light, and both the holder and interior support is plastic, no metal. So i discarded the possibility of some connection through the support.
Posted: Thu Dec 13, 2018 7:09 pm
by jsilv
It works!!! After "zooming", one photo that i found in some ebay ad :lol: :lol: :lol:
- the red wire to positive terminal of ignition coil;
- the black wire to negative terminal of ignition coil;
in other ebay ad, the seller say that "This tacho is not polarity sensitive" :D
unfortunately i cant read the all warnings in the photo :lol: :lol: :lol:
l) about positive earth installations, with is not my case, one less :lol:
the h) and i) can be a problem :lol: :mrgreen:
the "Note" is something like this: "this tachometer will not be damage if momentary miss connection but is .... wrongly connected it will read incorrectly and eventually its eletronic components may be destroyed." :D
Posted: Fri Dec 14, 2018 4:50 pm
Glad you got sorted.
Posted: Fri Dec 21, 2018 9:23 pm
by jsilv
mk1 wrote:Glad you got sorted.
Just another question :D , with this oil guage whats is needed for installation? I suppose that you already install a fews :mrgreen:
this?
http://www.minispares.com/product/Class ... 0to%20shop
Thank You!
