Gear Linkage Bush
Posted: Mon Apr 30, 2018 11:32 pm
by docka
Is there a replaceable bush in here? seems quite a lot of movement, even for a remote/wand conversion...
if so, does anybody know the part number and what's it like to change?
Re: Gear Linkage Bush
Posted: Mon Apr 30, 2018 11:57 pm
by CooperTune
2 A 3502 MSC two each. Steve (CTR)
Posted: Tue May 01, 2018 12:12 am
by docka
Cheers. Are they difficult to swap out?
Posted: Tue May 01, 2018 9:47 am
by Peter Laidler
Isn't there a round oil seal in there too as I recall? You'll also need a new grease nipple too as the head part of the one shown has been knocked off. That could be the reason why the shaft is so loose
Posted: Tue May 01, 2018 10:06 am
docka wrote:Cheers. Are they difficult to swap out?
Been a while since I last did these, but I cut a thread in the old bush and then pull them with the slide hammer.
Peter Laidler wrote:Isn't there a round oil seal in there too as I recall?
The Oil Seal is on the shaft going in to the main part of the case
Posted: Tue May 01, 2018 10:50 am
by Peter Laidler
Yep....., you're right as per usual Chris. I seem to recall that unless the grease nipple teat thinggy is set at the right angle, it's impossible to click a grease gun onto it, hence the fibre washer that enables you to position the nipple. And you know how frustrating it can be not being able to click onto a nipple
Posted: Tue May 01, 2018 11:21 am
Peter Laidler wrote:Yep....., you're right as per usual Chris. I seem to recall that unless the grease nipple teat thinggy is set at the right angle, it's impossible to click a grease gun onto it, hence the fibre washer that enables you to position the nipple. And you know how frustrating it can be not being able to click onto a nipple
Yes, quite Peter. Originally, they didn't have any grease nipples at all !!
And if I recall the workshop manual states that these should only be greased at times of 'major overhaul'
Posted: Tue May 01, 2018 11:59 am
The bushes are available from Minispares etc, but do need sizing on the ID.
Posted: Tue May 01, 2018 12:36 pm
by rich@minispares.com
they are a swine to get out as you cannot get them out with a slide hammer or a punch.
this is how I do them
drill them and tap them 5/8 unf
then screw either a allen stud in or i use the bango bolt from a oil pipe as the punch sits inside it nice
knock them out
refit the others using a stepped punch in tool (made from an old adjustable tie bar)
the standard replacements you can get shouldnt need sizing to the normal shafts, a lot of the shafts are really worn, so its possible to get undersize bushes that then need line reaming to suit, but i doubt that makes that much difference
Posted: Tue May 01, 2018 6:15 pm
by docka
Thanks for the advice guys, i'll give Rich's method a go...
Meanwhile, where do these bits go then?
They came with the remote/wand conversion bits from Minimail...
Posted: Tue May 01, 2018 10:53 pm
They go in the female knuckle and stop it ratteling
Posted: Tue May 01, 2018 11:09 pm
by docka
rich@minispares.com wrote:They go in the female knuckle and stop it ratteling
In the smoking pipe part?
Posted: Wed May 02, 2018 9:31 am
yes
they don't all have them, I think it might have been a ado16 part, but I always fit them if I can find them as it takes a little bit of the slack out of the linkage
Posted: Wed May 02, 2018 9:57 am
rich@minispares.com wrote:they are a swine to get out as you cannot get them out with a slide hammer or a punch.
Sure, they are tight, but I've never had trouble with the slide hammer, 2 or 3 hits and they're out.
Posted: Wed May 02, 2018 11:15 am
Spider wrote:rich@minispares.com wrote:they are a swine to get out as you cannot get them out with a slide hammer or a punch.
i find that as the are butted up to the alloy case, there is no space to get the decent slide hammer attachement 'hooked' over the end of the bush
my other slide hammer that is like a rawl bolt sort of thing that grips the walls of the bush tends just to slide out as the material is so soft - plus you end up punching yourselt in the face with the slide hammer (or is that just me!)
much easier to quickly tap them and knock them out!
what ever method used, they are well worth swopping
Posted: Wed May 02, 2018 11:48 am
rich@minispares.com wrote:Spider wrote:rich@minispares.com wrote:they are a swine to get out as you cannot get them out with a slide hammer or a punch.
Ah, OK,,,,
I have a fitting that I can use various sized bolts on it
what ever we all used to working with
Posted: Wed May 02, 2018 10:22 pm
by docka
rich@minispares.com wrote:yes
Cheers, it seems a very tight fit...
Posted: Tue May 08, 2018 11:45 pm
by Jim1071
knock them out
I put the new bushings in from mini spares and found they move in the bore
so I had to remove them wipe clean and use epoxy them
