two heads on ebay
newtune
Re: two heads on ebay
Post by newtune »
The arden looks nice, not so sure on the westlake needs a bit of work plus the chambers look very small.
James
COOPERCO
Post by COOPERCO »
Nice big lump of weld in the plug hole on the Weslake! :shock:
In the garage with tourettes!
newtune
Post by newtune »
COOPERCO wrote:Nice big lump of weld in the plug hole on the Weslake! :shock:
Have you not seen Simon's latest westlake all the plug hole are welded plus a whole lot more :shock: :shock: he got some long hours on the trusty bridgeport.
James
251 ENG
Post by 251 ENG »
Thats,s a lot of money :o
That is one expensive door stop!
Vegard
Post by Vegard »
Toby
Post by Toby »
looks like some serious repairs been done to it, any leaks from the cracks?
T.
littler
Post by littler »
:geek: seen that paper weight before ..
Vegard
Post by Vegard »
littler wrote::geek: seen that paper weight before ..
Yup, on Marks old forum that is ;)
masnarda wrote:looks like some serious repairs been done to it, any leaks from the cracks?
I've had it pressure tested and it DID NOT leak. The only repair is the one between the valves. Apart from that it looks quite good.
