Page 1 of 2
NOS Hydrolastic displacers markings
Posted: Fri Aug 18, 2017 1:42 pm
by STG95F
I know its a strange one , but did all the Hydro displacer hoses come with this yellow Dunlop marking on the hoses when new ?
Re: NOS Hydrolastic displacers markings
Posted: Fri Aug 18, 2017 1:52 pm
by Craig
I will have a look at my NOS ones a little later today and post a picture....
Craig
Posted: Fri Aug 18, 2017 1:54 pm
by STG95F
Great thank you ,
I have only seen one like this , all the rest had no markings
Posted: Fri Aug 18, 2017 2:04 pm
by 360gts
Yes, some have yellow...most have red. This is not indicative of the displacer hardness....that is usually depicted with paint around the hose and a couple of 'dabs' on top of the rubber part as well as paint around the metal unit with a P/N.
I have a few NOS sets that reflect this.
Posted: Fri Aug 18, 2017 2:12 pm
by STG95F
thank you
Posted: Fri Aug 18, 2017 2:33 pm
by Peter Laidler
From the enquiries I have been making recently regarding the repair to/of hydro units the opinion among the many local Oxford area hose repair or RE-hose specialists is that these braided type hoses were a lower end of the pressure scale type hose made by Dunlop Hyflex. You can still find it occasionally at the odd hose repairers who have taken over the Dunlop-Hyflex brand. Forgot to say but my new green banders from Unipart, fitted in '86 have yellow (now illegible) markings on them. Thanks to you I can now decipher what the markings were!
NOS sets 360gts..... you really need to off load that extra stock - with a green bander to me!
And while we're all at the back end of our cars.......... Anyone out there got the rear struts out of the hydro units, out on the bench? Could you measure the diameter of the strut, the exact length OF THE FULL DIAMETER PART plus the length of the insert part that slides into the hydro unit.......... and anything else you can think of. I think I'll turn up a couple from stainless steel while I'm in a bit of a bull-shxx mood and take the rear apart - again! Many thanks
Added as an afterthought...... I asked Somerford's if they had one I could measure but they're out of stock and have been for ages. Apparently, they can't find anyone to make them! Nope......, I refuse to believe it too. Probably a stock SAE mild steel bar stock cut to length and machined down at one end. Probably not a fast mover, a part that wears out or rusts away!
Posted: Fri Aug 18, 2017 6:17 pm
by STG95F
Peter, according to Mini spares site this part can be cut down and used for hydro cars and they are not expensive
http://www.minispares.com/catalogues/cl ... spx?1~8~71
http://www.minispares.com/product/classic/HILO-01.aspx
Posted: Fri Aug 18, 2017 6:29 pm
by Daz1968
Looking at the catalogue page where does item 4 the compression spring fit, as unless it's inside the rod I don't think I have one on my car.
Posted: Fri Aug 18, 2017 6:32 pm
by Peter Laidler
Thanks for that Stig but I just want to make a shiny set out of stainless bar that I have. Regards from Oxford
Posted: Fri Aug 18, 2017 6:34 pm
by STG95F
Inside the rod behind the dowel Daz . can be a pain to get out
Posted: Fri Aug 18, 2017 7:03 pm
by Peter Laidler
I'm glad Daz raised the point but I've often wondered why the spring is there? Any ideas?
Posted: Fri Aug 18, 2017 7:14 pm
by InimiaD
I've got all those bits you want measured up loose in the shed. I'll have to round them up and get my wooden ruler out.
The struts come in different lengths by the way.
Posted: Fri Aug 18, 2017 9:10 pm
by Peter Laidler
You're right....... Certainly the 3x parts lists I've looked through list 3x part numbers, presumably for different lengths! Mk1 given as 21A 1497, the Mk2 (mine is a Mar'69 Mk2) as 21A 1805 and the Mk3S is given as 21A2276. If I can have the outside dia and length of the largest diameter part of the longest you have. I'll prepare the new struts and finally measure up and machine for identical length when mine are out.
I can't understand the difference between a Mk2S and a Mk3S. But hey, if life were simple it'd be too easy. Mind you, now I'm sitting back thinking why the hell am I doing it? Thanks again
Anyone any idea why there's a spring inside?
Posted: Fri Aug 18, 2017 9:21 pm
by Nick W
Peter Laidler wrote:You're right....... Certainly the 3x parts lists I've looked through list 3x part numbers, presumably for different lengths! Mk1 given as 21A 1497, the Mk2 (mine is a Mar'69 Mk2) as 21A 1805 and the Mk3S is given as 21A2276. If I can have the outside dia and length of the largest diameter part of the longest you have. I'll prepare the new struts and finally measure up and machine for identical length when mine are out.
I believe its to stop it poping out of the displacer, when theirs no load , ie when the vehicle is airborne
Nick
Posted: Fri Aug 18, 2017 9:39 pm
by Peter Laidler
With the car airborne...., wheels dropped....., wouldn't the presence of a spring inside the shaft thinggy make it MORE likely to push the shaft out of the displacer? Not in mine it wouldn't because the small diameter bit was rusted into the displacer and the shaft and the spring! Last time I stripped it I just cleaned it all out and put in two springs from a local; commercial spring maker who loaded up the decent remaining spring and came back 5 mts later with a matched pair!
The good news is that taking Stig's advice I re-read the parts list he mentioned and there it says 21A1805 strut is the Hi-Lo strut cut to 245mm. That's probably the answer - staring me in the face.
Off at a tangent but I've really enjoyed getting my hands and overalls dirty this summer, under my S especially after doing sod-all to it for the past few years. Makes me realise how much I like the car. But a sad week..... My brother in law who bought a brand new tweed grey/white S in 1965, MMD 216 C and did a bit of bit part racing in another 522PUR died this week of the dreaded C. He started me off on this lifelong love of Mini Coopers. Farewell Brian
Posted: Sat Aug 19, 2017 5:24 am
by Craig
Well my "Green" displacers have red markings on the hose
Craig
Posted: Sat Aug 19, 2017 7:02 am
by smithyrc30
Very good used or even new rear S damper with two silver dots and two silver bands:
https://page.auctions.yahoo.co.jp/jp/auction/x495740028
Shows the marking protocol for the dampers
Posted: Sat Aug 19, 2017 9:05 am
by mab01uk
Posted: Sat Aug 19, 2017 10:30 am
by InimiaD
InimiaD wrote:I've got all those bits you want measured up loose in the shed. I'll have to round them up and get my wooden ruler out.
I found 3 loose struts and they all measured roughly 246mm long x 18.90mm in diameter.
I think 2 of the struts are off my MK 2 S.
On another rear wet subby I measured the in-situ strut at 250mm.
I think that subby came off a 66 ish Elf or Hornet.
From this mornings findings it looks as if the later the Hydro car, the shorter the struts.
Posted: Sat Aug 19, 2017 11:24 am
InimiaD wrote:InimiaD wrote:I've got all those bits you want measured up loose in the shed. I'll have to round them up and get my wooden ruler out.
The different length struts were used with the early & late displacers. If I recall right, the shorter ones were used with the earlier displacers (the ones that are set further down the body).
