Crabbing ... advice please
Posted: Sun Feb 20, 2011 1:11 pm
Been driving my car (which is to be used for historic road rallies) yesterday after having reassembled the rear suspension / subframe.
Noticed the car feels strange when driving in the straight ahead position , lots of small correction to the steering when travelling straight ahead, bumps in the road seem to amplify the feeling of instability. The car is not hugely unstable but does not instill confidence that one would want to do high speed with this characteristic in the handling at present.
Have determined the car appears to crab slightly ( tendency for the near side rear to steer towards nearside of road ) from visual assessment whilst following the car.
Heres what I have changed or modded
I have removed the adjustable camber brackets and replaced with std rover ones but have filed the radius arm hole in order to get the wheels vertical ( actual measurement now is n/s -0 degrees 8 minutes negative / o/s 0 degrees 5 minutes negative )
Have replaced the radius arms with new Rover units
Had the car on four wheel alignment with two shims behind the outer radius arm bracket mounting left and right side of the car
measurement on the rear showed I have 1degree 37 minutes of toe out on nearside and 35minutes of toe out on drivers side. I shimmed the brackets on the basis I thought I would have toe in with its standard setting ( no shim ) as I was aiming to get the rears to run parallel
I then removed both shims from the nearside and one shim from the offside but have not had the vehicle measured since.
In this condition the car exhibits slight crabbing and feeling of instability.
Having read the Minispares site the shims I have used should only alter the toe by around 10minutes so if this is accurate then I should have approx 1degree 17 minutes of toe out nearside rear and around 25 minutes of toe out on offside rear.
This does beg the question that although the Mini should be toe in usually in standard form my car does not show it has that.
I could file the radius arm hole in the nearside bracket to bring the outboard end of the radius arm on the nearside closer to the heel board to remove the toe out and bring the toe on the rears to parallel.
Sensible comments and advice please before I do anything further.
