My mk2 cooper
Daz1968
My mk2 cooper
Post by Daz1968 »
Thought it was about time I added some content to the site and show where I am with my project as may be asking a few questions shortly when I start putting things back together
Here are a few details of my current project and progress so far, it's a 1968 mk2 cooper that has been owned by me since approx 1984 although restored pretty poorly back then, it had been off the road since 1998 so I decided to redo the restoration once I had finished my mk1 project.
It's easier for me to say what's left of original shell, basically bulk head and cross member, upper and lower dash rails, upper of both side panels and rear panel, rear shelf, b posts and roof. Everything else I have replaced with a mixture of mainly m machine, heritage and a few magnum panels.
I am now nearing end of body work so just a few pics to show work so far
For anyone interested I have a full thread on mini forum
http://www.theminiforum.co.uk/forums/to ... k2-cooper/
Now a couple of where I am now
filling is one job where a lot of work doesn't make anything look different
I have almost finished main body filling now and will remove a door and start on one of those this weekend.
A couple of pics
Then with aid of vat free voucher I bought this
At least I have something to fill in the time whilst waiting for filler to go off prior to sanding, seems to work ok so far
Nick W
Re: My mk2 cooper
Post by Nick W »
Hi Daz
Looks like you are doing a proper job their!
What filler are you using?
We use a lot of Upol Fantastic ...its the lightest one you can buy and blocks down nice.
Nick
Up North in Sheffield
Daz1968
Re: My mk2 cooper
Post by Daz1968 »
Thanks, I am also using upol fantastic and epoxy high build primer. Have some dolphin glaze for minor imperfections later, I like upol stuff and find it sands easily with p180 paper.
Re: My mk2 cooper
Great work Daz, you are inspiring me to dig out my 68 Cooper and restore that (again). 8-)
What month 68 was your car built ?
InimiaD
Re: My mk2 cooper
Post by InimiaD »
The "sponge of doom" certainly did a good job of rotting out the top of the A pillar. :(
Fine work Daz.
Daz1968
Re: My mk2 cooper
Post by Daz1968 »
Thanks,
It's a June 1968 and registered on 11th June day before I was born so couldn't wish for a better one really. Been abused a lot and had 1300gt engine in when I got it, now has an original 998 cooper engine but with 4 synchro s ratio box which I will keep rather than fit a 3 synchro. I will be modifying it slightly by following the downton no 4 touring spec to hopefully make it a little better, and it will keep its Dunlop d1 alloys. I am really looking forward to getting it back on the road.
Yes the sponge really made a mess of it, pity no repair sections available for this area though
I was pleased with my fabricated effort though
Red Mist
Re: My mk2 cooper
Post by Red Mist »
Great work! Will be starting the resto of my '69 Mk2 very soon so this is giving me some much needed motivation!
Neil
Daz1968
Re: My mk2 cooper
Post by Daz1968 »
Finally got a little update, I have removed remaining paint and spent a few weekends filling and block sanding,
Then yesterday managed to get a couple of coats of high build on, so now the flatting can begin
java gt
Re: My mk2 cooper
Post by java gt »
For a Mini that looked pretty solid to start that is an amazing heap of panels removed from it.Are they heritage rear quarter panels you used?
STG95F
Re: My mk2 cooper
Post by STG95F »
Looking great Daz
Daz1968
Re: My mk2 cooper
Post by Daz1968 »
Thanks,
The rear quarters are magnum panels. Not a bad fit and a considerable saving over heritage. I should get it flatted with p320 this week and then can work on any outstanding imperfections, problem with primer is it makes everything look good
Callum
Re: My mk2 cooper
Post by Callum »
Nice work daz, not far off now!
tedmcedd
Re: My mk2 cooper
Post by tedmcedd »
Fab work!
Seems everyone has a Mk2 cooper!! I have one myself I'm doing at the moment!
Callum
Re: My mk2 cooper
Post by Callum »
tedmcedd wrote:Fab work!
Start a build thread! I also thought that the other day, there seems to be a few being built at the minute. I have another one to do once mines finished
Daz1968
Re: My mk2 cooper
Post by Daz1968 »
Thanks for comments,
Yes get a few pictures up.
If my paint turns out as good as Callum's then I will be pleased
STG95F
Re: My mk2 cooper
Post by STG95F »
I have one waiting to be done , but its way down my list ;)
Re: My mk2 cooper
Mine needs doing again, but it's just been pushed back to 2nd in line ;)
seandoyle
Re: My mk2 cooper
Post by seandoyle »
Just about to paint my Mk 2 after wasting 2 years in a body shop. Brought it home in Nov 17 & cracked on ,front end, re build doors , new boot floor....... I am sure you know what it takes , time wise & work involved. Should be lots of them about next year, but maybe not many in Antelope. Will paint roof white as I like the two tone look. Thanks to Callum for his posts, a real inspiration.
STG95F
Re: My mk2 cooper
Post by STG95F »
Mine is a late mk2 in monotone antelope , not a colour you see often
Daz1968
Re: My mk2 cooper
Post by Daz1968 »
After seeing loads of people having trouble with Photobucket new terms of use I have set up a Flickr account, not sure if it will continue working but have posted an update to test
It's getting there but still more work required
Gave it a few coats of 2k high build and been flatting with guide coat only a few areas left now that require a little work
ImageIMG_1967 by darren carr, on Flickr
ImageIMG_1966 by darren carr, on Flickr
ImageIMG_1963 by darren carr, on Flickr
ImageIMG_1965 by darren carr, on Flickr
ImageIMG_1964 by darren carr, on Flickr
