early 997 cooper head
Posted: Sun Jan 23, 2011 6:35 pm
by littler
hey all , i have just found a 12A185 / AEA626 head
reading from the exhaust side of the head behind the stat houseing it has stamped
S.522
A.V 19.7.
its been ported quite well and has really odd domed valve faces.
anybody got any ideas who did it??
Re: early 997 cooper head
Posted: Mon Jan 24, 2011 11:43 am
Alexander were very keen on using domed valves,
A. V19.7 could also point in this direction too, but I don't know for sure.
A (Alexander?)
V19.7 (Volume 19.7cc)
I assume the other number is a job number Number (No: 522)
As I say, this is assumption based on the fact I have had a number of Alexander heads & most have had domed valves at least in the exhausts.
Posted: Mon Jan 24, 2011 11:46 am
Oh, by the way an AEA626 head should be a large bore 1070 S head, not a 997 Cooper head.
Posted: Mon Jan 24, 2011 8:49 pm
by 251 ENG
That sounds like a genuine Morris Engines modified head .
Is it 9 or 11 stud ?
Is it drilled for a heater tap or is the casting blank ?
Posted: Mon Jan 24, 2011 9:10 pm
by littler
well its a small bore 9 stud casting.
yes there is a heater tap take off, i will take some pics
you guyes have got me quite enthused.
Posted: Mon Jan 24, 2011 9:12 pm
by littler
mk1 wrote:Alexander were very keen on using domed valves,
A (Alexander?)
this is pretty much what i thought as to the meaning of the numbers, as for alexander i hope so
mark didnt you have an alexander head for sale?
Posted: Tue Jan 25, 2011 8:05 am
Hi,
I did have a Alexander modified 997 Cooper head for sale. But from what Simon says he recognises the numbers.
An AEA626 is definitely a large bore head, so I can only assume that this one is a small bore 12A185
Posted: Wed Jan 26, 2011 7:24 pm
by littler
well the head has 12A185 hetween the centre rocker post moorings and AEA626 between the stat houseing end two.
ive got what i beleve to be an early downton 185, but is is lacking the AEA number.
so it being genuine Morris Engines modified head meaning it was a factory devlopment project?
ill take some pics in a bit.
Posted: Wed Jan 26, 2011 7:27 pm
by littler
oh yer, i have just knoticed it doesnt have a temprature sender hole below the stat houseing.
Posted: Wed Jan 26, 2011 7:56 pm
by littler
Posted: Thu Jan 27, 2011 8:06 pm
by nick rogers
The factory did this to try to confuse us. Two completely different heads with the same casting number 12A185. It's very obvious which is which. I have owned a couple of 11 stud 185's both of which ended up in Simon's shed. I still have some 9 stud 185's.
Posted: Thu Jan 27, 2011 8:14 pm
by ricardo
Yes, but this one is a small bore and has the AEA626 too which should refer to the big bore head. Very confusing.
Posted: Fri Jan 28, 2011 7:40 am
by 251 ENG
Posted: Fri Jan 28, 2011 8:13 am
Its the AEA626 that I find very confusing!
I have seen & know about the confusion re 12A185's & have seen examples of both, but I have only ever (before this week) seen large bore heads with an AEA626 casting number on them.
Sorry about the rubbish picture, its the only one I have handy.
Had anyone heard of these small bore ones before?
Posted: Fri Jan 28, 2011 8:49 am
by ricardo
This one that was on the first forum was for a 948 engine and had the AEA626 too. Looks more like a small bore casting, but still not close to littler's head. So, are there 3 versions of AEA626?
As for the other head, the numbers do look like downton.
Posted: Fri Jan 28, 2011 7:51 pm
by littler
thats good, ive allwase thought it was downton,
that head above, im guessing formula juinor? what the hell does the stat houseing look like for that !
Posted: Fri Apr 08, 2011 8:24 pm
by littler
BUMP , this head may be up for sale if anyone is interested?
Posted: Sat Nov 05, 2011 9:15 am
by Toby
Does anybody have an AEA626 big bore head for sale?
Mark you had one in your shop some time ago, would you still have it?
