Inlet manifold help
Posted: Thu Jun 09, 2016 9:27 pm
by coopertim
Evening all
Im trying to fit the twin carbs to my 12A185 head but my 12A661 inlet manifold takes locating rings and these will not fit into the head. Any ideas on which manifold part number i need please? Struggling at the moment and would like to pick one up from Beaulieu if i can.
Cheers Tim
Re: Inlet manifold help
Posted: Thu Jun 09, 2016 9:33 pm
by 1071bob
Posted: Thu Jun 09, 2016 9:59 pm
by BRI MK1
Hi Tim just drill and pin the manifold i will give you a call tomorrow evening cheers Brian.
Posted: Fri Jun 10, 2016 6:25 am
by mini63
you can still use the 661 manifold Tim by lining it up by feel with carbs off. You'll still have the groove in the inlet tracts where the ring seats but otherwise will be fine.
other wise the early 997 manifold with stud ears will be the one assuming you have no vacuum port needs.
cheers M
Posted: Fri Jun 10, 2016 3:06 pm
by nick rogers
Tim, I believe I still have a 12A309 manifold in the van which is packed ready for Beaulieu. I would swap it for your 661 if you're interested.
