Assuming you have the head off, Put some Plasticine (or Blue-tac) on to the crown of No. 1 piston, then wipe some oil over that (so it doesn't stick to the head / valves), set the pistons to around mid-stroke,fit the head on with an old gasket (or even no gasket), fit the push rod in for No. 1 Inlet, initially set the tappet clearance by feel is good enough, give it some extra (say even a couple of mm), SLOWLY wind it over by hand while looking in through the spark plug hole, at the right angle you'll be able to see the Valve opening and the head of the valve, keep winding over slow while watching and feeling if it wants to stop or if there's any interference. If all looks good, set the tappet clearance for real and go again.
With the rings on, this can be a bit hard to feel for, I usually do it at the dry build stage, then you're not fighting the rings and you can really feel everything.
By doing this check without a gasket, that will give that added margin when done for real.
If you have a vernier timing gear set, you can set the timing to say 105 degrees and check what clearance you have there and that will guide you if there will likely be issues. At 105 degrees, you will be 'safe' but when you start getting down to around 102 - 103 degrees, especially with a cam like that that opens so early, then check check check.
If you find you have clearance but is close, best check all cylinders as there will likely be some variation between them.
Apart from the long duration, early opening of the cam itself, you need to get the CR up which can compound the issue of valves kissing the pistons as you'll likely have the pistons flush or coming out of the deck and / or shaved the head, and with each of these steps, bringing the valves and pistons ever so closer together.
Given your build, if 97 Octane Fuels (or better) are available and permitted to be used, I'd be aiming for a Dynamic Compression Ratio of 8.8 - 8.9:1, which without crunching the numbers, would likely be in the region of 12.5 to 13.5:1 SCR. A low CR will make it hard to start. You may also find you'll need to fit a hotter plug to start it and warm it up a bit then fit cooler plugs for the runs.
Also, and this is just my thoughts, if it were me, I'd probably be more inclined to reach for a 643 for Rally work along with a 4.1 Diff. If I were to go for a 648, then 4.3 or a custom FD at around 4.5 or 4.7:1. Top end speeds generally peak at around 80 mph (though there maybe the odd one that will get to 100) so, if it were me, I'd start on paper from that and work back to see if the other end of the spectrum will also be satisfactory.
Sounds great build.
Rich - sure, a 1430 will come on at lower revs and almost getting into that streetable region
