Repairing Mk2 lower Dash rail 'dents'
rolesyboy
Has thanked: 19 times
Post by rolesyboy »
Any folk out there know of a way to repair the lower crash rail/dash pad on a Mk2. I have a dent in mine but the black coating is intact. Thanks. Mark
Daz1968
Re: Repairing Mk2 lower Dash rail 'dents'
Post by Daz1968 »
Would think you would need to remove it and try to push out from the back, not easy though as the foam is brittle.you could always try a little heat on the area.
NicholasUpton
Post by NicholasUpton »
I have had luck in the past using my steamer to puff foam back up, and bring things into shape.
swifty
Been thanked: 43 times
Post by swifty »
Take the dash pad out and drill a 5/16 or bigger hole carefully in the foam , blow out excess with a airline . Then spray in the hole with expanding foam rattle can . Use masking tape to stop the expanding foam from coming out . As the foam cures it pushes the dent out . Works a treat .... Ken
1963 austin Cooper s mk1 1071
1966 Austin Cooper s mk1 1275
1968 Austin Cooper mk2 998
1962 Morris mini super 850
Porsche 997 turbo S
Ford transit van 280s.
I am from Essex
Matt_Tupman
Post by Matt_Tupman »
swifty wrote:Take the dash pad out and drill a 5/16 or bigger hole carefully in the foam , blow out excess with a airline . Then spray in the hole with expanding foam rattle can . Use masking tape to stop the expanding foam from coming out . As the foam cures it pushes the dent out . Works a treat .... Ken
What a great idea I shall be using that next time.
