5 bolt bumpers question
Posted: Mon Jan 04, 2016 3:51 pm
by almondgreen
I have a question about 5 bolt bumpers.
How long have they been fitted to Minis ?
When was the change to 3 bolt ones.
Are all 5 bolt ones, original, or where 5 bolt reproduction ones made ?
Re: 5 bolt bumpers question
Posted: Mon Jan 04, 2016 8:58 pm
by Spitz
A friend's 64 Countryman I looked at yesterday has holes for the 5 stud bumper
Posted: Mon Jan 04, 2016 9:19 pm
by Simon776
There were after market five mounting bumpers, but they use tags across the underside of the bumper so look quite different to a genuine one - at least on the underside.
Posted: Sun Jan 17, 2016 10:10 am
by Andrew1967
I've just picked up a couple of new 'old stock' repro 5 bolt bumpers - manufactured as Simon says.
Different profile (larger radius) than the originals by the looks of it.
Posted: Sun Jan 17, 2016 12:11 pm
by cpr1
Andrew1967 wrote:I've just picked up a couple of new 'old stock' repro 5 bolt bumpers - manufactured as Simon says.
Had some like these, and they were a pig to fit. :x
Posted: Sun Jan 17, 2016 5:42 pm
by Andrew1967
It'd certainly be a pig to fit on the back of the pick up :shock: .... :lol:
Posted: Wed Aug 30, 2023 11:44 pm
by rogerotto66s
This seemed to be the “proper” topic to bring back to life!
I just purchased a set of 5-bolt bumpers (bottom in picture).
They do not have holes for corner bars.
Their profile is quite different when compared to my original 5-bolt bumper (1966 Austin Cooper S - top in picture).
- the corners are rounded with no sharp edges
- the bolts are mounted in a different manner
Can anyone provide info re: the timeline for the change in 5-bolt bumpers.
Posted: Thu Aug 31, 2023 8:11 am
by Old English White
The bumper(s) you have purchased are the reproduction/aftermarket bumpers which Simon referred to in his post above. They are not an original fitment to any Mini.
Posted: Thu Aug 31, 2023 11:25 pm
by rogerotto66s
Any conversion date for 5-bolt going to 3-bolt?
Any date range for the after-market bumper?
Posted: Fri Sep 01, 2023 12:16 am
by 360gts
rogerotto66s wrote: Thu Aug 31, 2023 11:25 pm Any conversion date for 5-bolt going to 3-bolt?
Must have been after MK2 production ended...I have had two MK2 S's
and they were fitted with the original 5 bolt bumper.
So, question is..were the 3 bolt bumpers ever fitted as standard or were they just replacements?????
Posted: Fri Sep 01, 2023 9:55 am
by Allen Brzeczek
I am of the considered opinion that the 3 bolt bumpers are an after market replacement. I fitted a stainless steel pair on my 67 S some 3 - 4 years ago which look OK but found that I had use rubber insertion on the front at it was prone to vibrating noisily especially on tick-over.
Have retained the originals for possible re-chroming at some later date.
Posted: Fri Sep 01, 2023 11:27 am
by MiNiKiN
rogerotto66s wrote: Wed Aug 30, 2023 11:44 pm This seemed to be the “proper” topic to bring back to life!
My original Innocenti bumpers look very similar with the same kind of bracket - so my best guess is that they are Innocenti
Posted: Fri Sep 01, 2023 5:03 pm
by rogerotto66s
MiNiKiN wrote: Fri Sep 01, 2023 11:27 am My original Innocenti bumpers look very similar with the same kind of bracket - so my best guess is that they are Innocenti
Just found this on eBay.
It is described as an Innocenti bumper.
Posted: Mon Sep 04, 2023 8:18 am
by MiNiKiN
rogerotto66s wrote: Fri Sep 01, 2023 5:03 pm
Behold, I told you so :D
Posted: Mon Sep 04, 2023 9:06 am
by Peter Laidler
I saw my first 3 bolt bumpers in the mid 70's when I was doing some work on my run-about 998 MSM130F and I am positive that they were Unipart, covered with that white stuck-on tape that was a bxxxxxd to get off. I feel that the 3 bolters were a means of cheapening production - by Leyland cans
