Single HS6 Manifold
Posted: Fri Jan 01, 2016 2:29 pm
The Howley on my 1480cc road engine is getting a bit tired and
I need to replace it...
It is possible that the ports are a bit on the small side, but what
I do know is that this manifold gave "noticably" more bottom end
than the MiniSpares one that it replaced. This was when the same
engine was "only" 1380cc... The MiniSpares manifold was also quite
a few years old and they may have changed the design since.
Presently the spec is:
74mm x 86mm = 1480cc
Ally Head - CR 11:1 Appx - 1.5 rockers
Rimflow Inlets - 1&15/32" (1.468" or 37.3mm)
Rimflow Exhausts - 1&7/32" (1.218" or 30.9mm)
(NB - These are "proper 37.3mm" valves,
not 1&7/16" (1.4375") = 36.5mm, "rounded up to 37mm".
(Please note, MiniSport customers))
HS6 Carb, Internally modded, radiused stack and K&N
Kent Megadyne 276 Cam, 270/280 degrees
Programmable 123Ignition Distributor
Maniflow Medium LCB
PlayMini system from the "cat-flange" back
... and it's got a chrome coil!
Any suggestions on a suitable replacement manifold?
(And, no, I am not looking for suggestions such as
"put a Weber on it").
I would, however, look into the possibility of using a HIF7
or HS8 carb should information come to light that these
would be feasable and better...
Would these carbs be too big?
I am thinking that the injection throttle bodies are larger than the
1&3/4" or 44.5mm that the HS6 has - I know nothing about the
injection engines, but a quick read told me that the throttle bodies
are 48mm and that a 52mm version is available...
Maniflow Medium LCB
