997 speedo change
rolesyboy
Has thanked: 8 times
997 speedo change
Post by rolesyboy »
I have a 100mph dead speedo which has the 5 digit plus 10ths of a mile trip, only 3 lights. high beam (blue), indicator (green) and ignition (red)
I also noticed has the 90 and 100mph inverted??
At what time point did this type of speedo get introduced?
Was the early 997 Cooper fitted without the trip?
mini63
Re: 997 speedo change
Post by mini63 »
Sounds about right. Inverted numbers, tenths trip, 3 jewels.
nick rogers
Post by nick rogers »
Is it 4479/06 ? If so, it was used from May 62 to Sept 64. It was the second type used on the 997 .
ianh1968
Post by ianh1968 »
Wasn't the "green" the oil pressure lamp?
... with the indicator being on the end of the stalk...
Ian
Has thanked: 125 times
Been thanked: 34 times
ianh1968 wrote:Wasn't the "green" the oil pressure lamp?
Ian
No lamp for Oil, they had a gauge.
minimans
Post by minimans »
Ian
Blocked filter light?
Ian
I'm pretty sure they came in after the 997 Cooper, though, I'm no expert on the model. I seem to recall in my mates 997 the green one in the speedo wasn't used.
ianh1968
Post by ianh1968 »
No gauge in a 1964 Morris Minor 1098 that I work on, only a lamp!
I was guessing that the 997 Cooper speedo would be the same...
(or at least very similar).
Ian
Spitz
Post by Spitz »
I believe ALL Coopers had the 3 gauges.....correct.....??
