Handbrake bracket ID
Posted: Sun Dec 20, 2015 7:28 pm
by Vegard
Lot's of IDing here now. :)
I've never noticed this difference before.
What is the difference? One cable, twin cable? ADO16?
Re: Handbrake bracket ID
Posted: Sun Dec 20, 2015 8:26 pm
by InimiaD
Top one is for twin cable. Bottom one is for single. More leverage.
Posted: Mon Dec 21, 2015 1:42 pm
by CooperTune
I will need to do some checking of hand brake parts at the shop. I was called on to completely rebuild the rear arms and brakes for a 59/60. I had to file fit the rear cyls in order to get the washer and snap ring in place. Then I found the hand brake linkage incorrect and the shoes would not lie flat against the backing plate. Inspection of the parts you show made it clear at some time the wrong linkage was installed. I changed them out and everything was fine. Thanks now I better understand what happened. Steve (CTR)
PS I keep spare outer bushing and made a special alignment guide for my reamer for doing welded arms.
Posted: Mon Dec 21, 2015 4:51 pm
by Tim Harber
The levers got more length over the years
Latest ones have best leverage (started early 90's)
Measurements not dates on arms
Posted: Mon Dec 21, 2015 4:58 pm
Now that is interesting!
Well spotted Tim.
