Cooper dash rail vinyl
Posted: Mon Dec 14, 2015 8:40 am
by Instant Gymnast
Right chaps, am having a spot of bother trying to get clear photos of the Cooper top dash trim. I want to know if the A pillar bits go on first and also how the ends are finished off (stuck down or sewn?). If anyone could post up any photos of their cars I'm sure this would be a great help.
Much appreciated....in anticipation....
Re: Cooper dash rail vinyl
Posted: Sat Dec 19, 2015 3:43 pm
by Hipwell
On mine, ends just stuck down.
A pillar trim over dash rail trim.
Posted: Sat Dec 19, 2015 8:43 pm
by Instant Gymnast
Hipwell wrote:On mine, ends just stuck down.
Nice one, thank you. So does the vinyl fold over the flange that the screen seals against? Looks like something I could probably crack out in a morning...(if it's dry...!) Also will I need to heat it with a hair dryer/hot air blower to hold it to the shape of the dash rail?
Posted: Sat Dec 19, 2015 11:24 pm
by Hipwell
Yes goes over the lip aswell quite a bit.
It's pretty crudely done as original, but if you take time it should be good.
Posted: Sun Dec 20, 2015 1:03 am
by smithyrc30
Don't go mad with a heat gun, the vinyl will stretch and the grain will look odd.
Use a good quality contact adhesive and let it dry before you bring the bits together.
If the pillar material is pre-cut to size and shape, start at the top and work down. I leave the last 10mm or so unglued so i can finish it up when I get there.
The most difficult bit is to get the material to fold back on itself and stay there while the glue cures.
I've seen bulldog clips, pegs, welding clamps and wooden battens but what ever you use be prepared before you start and have a plan.
It is not too hard if you are carefull.
Posted: Sun Dec 20, 2015 1:01 pm
by Rusty old S
The vinyl sometimes seems to shrink or peel back over time to show the body colour so around the top rail / pillar joint . what I do is to use a satin black spray can around this area so if it happens the eye is not drawn to it . I know its a bodge but it works !
Posted: Sun Dec 20, 2015 6:58 pm
by ricardo
Posted: Tue Dec 22, 2015 7:31 pm
by ranchlands
guys you,ve previously restored cars can you advise me on the best make and type of adhesive to use, your experience would be much appreciated
Posted: Tue Dec 22, 2015 9:04 pm
by smithyrc30
Dunlop Thixofix. Not sure but I think this is the stuff they used in the factory.
Tried evo-stick but it seemed to be thicker and more difficult to get an even thin layer.
