M-Machine front panels....
sandman
Post by sandman »
Anyone know what the M-machine frontpanels are based on / made of?
I.e; Heritage panel, Magnum (or other budget) panel - or of their own pressing?
Cheers,
Ed_
gs.davies
Has thanked: 49 times
Been thanked: 54 times
Re: M-Machine front panels....
Post by gs.davies »
I have an m machine front panel. Detailing by m a machine is very good. The spot welds holding the slam to the front pressing however, were not so good.. All loose and had to be re welded. Doesn't look heritage to me.
Dean
Post by Dean »
i sure they are heritage( but i could be wrong), then they change the slam panel is for the correct year/mk, weld up any holes that should not be there etc.
i had a full skirt front panel from them, and all they do it weld in the missing sections to the lower corners
NicholasUpton
Post by NicholasUpton »
From the dozen I have seen it is a modified Magnum panel
Rocket
Post by Rocket »
As above watch out for some poor spot welds
Daz1968
Post by Daz1968 »
By the price of them I can't see them being heritage, I plan on using one on my mk2 however but will buy the indicator plinths to fit as well, I used magnum front panel and wings on my mk1 and had very little hassle fitting them,
360gts
Been thanked: 37 times
Post by 360gts »
I thought I was doing the right thing...I bought a heritage front panel.
Hmmm!...usual issues..as stated in previous posts...spot welds are all wrong to start with.
Next, the indicator apertures are later style...not MK1.
The whole front parts is later style...the brackets for the license plate are later style as well.
Even the vertical support strap wasn't in the correct spot. The underside of the slam panel is also wrong...look closely at the picture and you can see the difference.
I spent days redesigning and changing the panel.
Ended up replacing the entire slam panel with one from an old car I had here..
Here is an example of the front end after it was remodeled. Have added a few arrows to show what is different.
Post by Old English White »
I had exactly the same issues with a Heritage panel. Very disappointed - especially as I'd visited the factory before ordering it and I was assured that it was "correct" for a Mk1 :lol: . Lord help us if the ever DO create a whole Mk1 bodyshell :shock:
rich@minispares.com
Post by rich@minispares.com »
as has been discussed before, the heritage panels are just wrong for correct useage in a mk1, its because they are constrained by having to use the presses which have been modified for later rover panels
the worse bit is where the inset is fitted into the press to get rid of the mpi cutout.
the m-machine panels are a far better bet, they might be based on a pattern panel, but it requires far less work to get right.
either one is better than trying to beat one out of a flat bit of tin, though, so we should be all grateful for the supply of either!!!
Richspec
Post by Richspec »
rich@minispares.com wrote:
'either one is better than trying to beat one out of a flat bit of tin',
Just make it all from alloy if you're called Paul Wiginton :!:
sandman
Post by sandman »
I really should know this, but have to ask;
What are the differences in the indicator area between Mk1 and Mk2,3,4?
Cheers,
Ed_
Tupers
Post by Tupers »
sandman wrote:I really should know this, but have to ask;
The flat portion is about 20MM larger diameter on the latter front panels. It's not a major difference but when you put a MK1 indicator on a later plinth there's a flat rim around the edge that looks a little odd.
MK1
MK3
Tupers
Post by Tupers »
MK3, MK1 and a preplacement slam panel section I made.
Difference between a pattern and OG MK1 brace.
The recess in the centre of the grill aperture is also deeper on the latter pattern front panels.
gs.davies
Post by gs.davies »
MK1
MK3
Bugger...
gs.davies
Post by gs.davies »
That by the way is an m machine mk1 panel. I can forgive the cut out but the plinths..?
Daz1968
Post by Daz1968 »
Just give them a call as they supply new indicator plinths to old spec if you want to change them.
360gts
Post by 360gts »
Had a couple of requests for a picture of the finished front panel. Bumper lip has been changed as well.
This is ready to go onto a 970...sept 64.
It has the cutaway skirt.
Catmint
Post by Catmint »
sandman wrote:Anyone know what the M-machine frontpanels are based on / made of?
I think they used to be based on Hadrian panels, but this was bout 10 yrs ago. Not sure now as Hadrian went bang a while back
Alex
Post by Alex »
Didn't Magnum buy up all the Hadrian tooling ?
sandman
Post by sandman »
Daz1968 wrote:Just give them a call as they supply new indicator plinths to old spec if you want to change them.
I assume one has to cut out and re-weld these?
Any one got a photo of the plinths they sell?
Cheers,
Ed_
