Tie rod length
Posted: Sat Nov 21, 2015 9:02 pm
by Dr S
I've got adjustable tie rods, and bottom arms on red shed. I'm aiming for a ride height about 1"-2" down from stock, with 1.5 degrees of neg. that much I can set with a protractor and some string, does anyone have a good starting length for the tie bars?
Re: Tie rod length
Posted: Sat Nov 21, 2015 9:19 pm
by GraemeC
From adjustable tie rod instructions:
"The standard tie rod length is 14.25" measured from the inner edge of the bottom arm retaining bolt hole to the outer face of the welded-on washer."
Re: Tie rod length
Posted: Sat Nov 21, 2015 9:36 pm
by Dr S
Cheers Graeme, I can work the new lenght out with a bit of trig from that. That'll get it close enough to drive down to be set up
