Removing metal air filter cap from brake servo
Does anyone know how to remove the metal air filter cap from a Mk 1 servo, it is held in place by 3 pins that do not appear to be spring loaded and the metal of the cap appears to be too thick to sping over the pins.
Re: Removing metal air filter cap from brake servo
Hi MGB,
Gently bend the three tangs out and it will come right off. When assembling, a couple of taps with a hammer will put them back in position.
Regards
Al
Regards
Al
