radiator shroud
coopers1968
radiator shroud
Post by coopers1968 »
hi guys,
any idea on how i can get the radiator shroud bracket to fit perfectly without fitting the engine prior? is there some measurement i can stick to? i have tried installing this in the past using previous welding spots but it didnt fit to perfect,
thanks
regards
chris
Morris mini 1275cc 65'
Austin mini cooper s 1275cc 68'
Austin mini Super deluxe 850cc 69'
R&R
Re: radiator shroud
Post by R&R »
If you want it perfect, you'll have to do it the hard way and fit the engine I'm afraid, but use everything you will use to install the engine i.e casings, mountings, steady bar, rad cowls, and rad brackets.
