I have just been quoted for a stage 2 tuning kit for my Elf, the quote advises that I will require the van exhaust system?
As the Elf /Hornet floor pan is the same as the Mini and it is the boot were the extension is I presumed that a longer/aftermarket chrome extension piece would be the way to go.
I know of someone that had a van exhaust fitted to his Elf some year ago now by a "Mini Specialist "
It hung that low he had to change the route he took home to avoid a speed bump that he previously had no problem navigating over.
I would suggest that you need a slaoon centre pipe (with or without silencer) and an estate rear box as per the link below. I am sure Maniflow would be able to do the right parts for you but you will probably have to give them a call to put in the order.
Yes spot on, the extra length is at the back of the boot so you only need to add an extension on the back end - we run a standard RC40 with an extension over the tail pipe to push it beyond the bumper.
