mk1 wrote:OK, I was close, but no cigar. My original comment was based on one overheard conversation in the pub
Mark, it was close enough to be a very valid point here
- Yes, resistors, and yes you have to wire them up correctly.
I was thinking about getting some of these myself, but am having
serious second thoughts now. I'm not overly fussed about power
consumption as I have a 70 amp alternator and I'm even less fussed
about the theoretical "extra" fuel that it would take to generate the
electricity to power the traditional type of lamps.*
I also don't find changing a bulb, probably on average once a year,
too onerous. Now a "CREE" headlamp conversion at a sensible price
would be another matter...
I hope that this gets sorted out on snoopy64's project because
otherwise it may turn out to be money down the toilet!
Ian
* Energy saving domestic lamps are another of my favourite gripes.
It is said that an 11 watt fancy lamp is equivalent to a 60 watt
traditional lamp - By definition, therefore, they say you are "wasting"
49 watts of electricity, on each one, no less!
"That's perfectly true", I hear you say, "Are you some kind of dim-wit
that cannot subtract 11 from 60?".
Well, yes, I can do that, but why do they consider the 49 watts of
electricity to be "wasted"?
"- Because it's just producing heat and not light, you idiot...
... and obviouly, this is totally bad under all circumstances."
OK, Mr Smart-Arse expert, you consider this then:
1) I have my central heating on for approximately 7 months of the
year, these are the coldest months, and also the darkest, when I
use my lights the most.
2) When it's dark, it's also generally colder, mostly because it's
night and the Sun has set. (Can you see where this is going, yet?)
3) My central heating system has a thermostat on it which detects
heat and turns the boiler on and off.
4) The thermostat is unable to tell the difference between heat
generated by the central heating, and heat generated by my
un-environmentally friendly collection of traditional light-bulbs.
Conclusion - During the winter months when my central heating
is running, the 49 watts of "wasted" electricity is
saving 49 watts
worth of gas used to heat the house... Only during the 5 months
of the year when the heating is not on would the electricity be
"wasted", but during these months the lights are not being used
half as much anyway.
Go figure!
... It's all a scam!
