Mini Cooper discs
Posted: Wed Oct 07, 2015 6:26 pm
by Daz1968
I am currently restoring a mk2 cooper still on its 7 inch discs, I am hopefully going to retain these as found them good enough for the car, question I have is the wheel bearings, the cooper has drum brake cv joints and plain roller bearings, I have some new timken taper roller bearings and am pretty sure I have read somewhere that they can be used in drum brake hubs so hopefully may fit in my application. Has anyone tried this with any success, I know I can fit the rear timken bearings I have so was hoping I could upgrade fronts at same time, still a while off doing though as body only just started but getting parts collected together ready.
Re: Mini Cooper discs
Posted: Wed Oct 07, 2015 8:15 pm
I think from the factory, the Cooper did have the Ball Bearings fitted.
Dimensionally, as an assembly, the Tapered Rollers and the Ball type Bearing assemblies are the same and interchangable.
<Edit to fix my shitty spelling / gramma >
Posted: Wed Oct 07, 2015 8:30 pm
by Daz1968
Thanks, that confirms it for me, I will fit the timken kits I have
Posted: Wed Oct 07, 2015 9:06 pm
I have nearly always fitted the Tappered rollers, regardless of what was found in them. I think there days the Ball Rollers are in fact dearer than the Tappereds.
Posted: Tue Oct 13, 2015 9:58 pm
by CooperTune
A little off topic but still 7 inch brakes. I stumbled over a nice set of 998 calipers recently. I just happen to have new SS pistons for a set. I also have a Moke with twin leading shoe brakes. I'm thinking about turning down a set of 7.5 disc and either thin them down or machine spacers for the calipers and use 7 inch disc with S drive flanges. Could thin some used S disc and machine a little off new pads. I have new 7 inch disc not sure how well fixed I am for 7 inch drive flanges. Steve (CTR)
